    arg 8bitdo SF30 problems
    8bitd0 n30n64
    3 Posts 3 Posters 632 Views
      ringus
      Okay, it works which seem to be a step further than some. SNES is perfect.
      But on the n64 the only way it works is if all other controllers are not plugged in (cheap wired ones which come with a kit).
      I fear I have messed something up as I am unable to get into the retroArch menu with either controller, but the saved state shortcuts work?
      Also the 8bitdo is never the default controller always player 2 , wish I could swap that.
      Thanks all, loving retroPie :)
        Markeno
        If someone responds and can give instructions on making the 8bit Default to Player 1 I would love to know myself. I wasn't able to come across anything on that myself.
          @ringus please provide some info about your setup, as asked in https://retropie.org.uk/forum/topic/3/read-this-first.
          @Markeno you too, provide the same info in a new topic, please.
