    System: rpi4 (armv71) vs System: rpi4 (aarch64)
    system info
    2 Posts 2 Posters 962 Views
    • F
      fmentiplay
      What is the difference between "System: rpi4 (aarch64)" and "System: rpi4 (armv71)"?
      Can you convert from System: rpi4 (aarch64) to System: rpi4 (armv71)?
        aarch64 is an ARM 64 bit system (kernel), while arm7l is 32 bit ARM.
        It depends. If you installed your system from the beta 64bit Raspberry Pi OS image, then no, you cannot convert. If you merely modified the /boot/config.txt file on a 32 bit Raspberry Pi OS and added the option to boot the 64bit kernel (arm_64bit=1), then you can remove that configuration line and you'll be booted back to a 32bit kernel/OS (arm7l).
