    retroarch cheat engine - How i can stop it after cheat founded ??
    retroarchcheatenginesearch
    1 Posts 1 Posters 523 Views
    • DjDiabolikD
      DjDiabolik
      Example... i have tryed to found some cheat whit a certain games.
      Using the internal Cheat Search Engine and apparently it's works whitout any issue.
      After some test i have found how i want... for example "Infinite lives" and after i have add a description i see this founded cheat it's be autoloaded every time i have reload the same game/rom.
      But i have an little question about this:
      After i found all value....... when i run the same game i see a message it's say "Successfully start Cheat Search" or somethings similar and it's and it happens as if I had started another search.
      The question it's.... it's normal ? I can stop this append ? How i can stop the Search Engine after i found somethings and simply load the cheat ?
