    Need Help Installing Openbor
    openbor
    1 Posts 1 Posters 344 Views
      Drdave79
      Hi all. I've combed this site as well as youtube and the net and I swear there isn't one clear cut, step-by-step instructional on installing Openbor correctly on the Pi4. I was hoping I could ask for some help please. I'm using my own retropie image.
      I installed both Openbor under Retropie Ports and Openbor V6510 under Retropie Extra Emulators. I've added Openbor to the es_systems.cfg and can see it in emulationstation (not under Ports. I wanted it as a separate system). I know there's some confusing information regarding the extensions for openbor files, but several of the images I've tried all use the .PAK extension and work. That being said, I have three files in the roms/ports/openbor folder. HE-MAN.PAK, Battle Toads.zip and Bruce Lee.7z. Just to see if I could get any to work.
      When I launch HE-MAN from Openbor in ES , for example, I double check and am using the openbor emulator (only choice). The game launches into the openbor secondary menu. When I select any game here, it takes me back to Emulationstation.
      So I'm obviously missing a step. Any ideas please? Thank you.
