    Help with retropie on retrodreamer cm4
    cm4
    4 Posts 2 Posters 801 Views
      kotif92
      Can someone explain what is this and how to fix it?
      I got my retro dreamer cm4 yesterday and wrote an A.R.E.S image developed by tech toy tinker. At first it was running ok but after writing more roms , something is off. Everytime i boot i have to reconfigure the controls and when i reset emustation, this shows up.
      I
        Sorry, we don't support 3rd party images, as explained in https://retropie.org.uk/forum/topic/3/read-this-first.
        You'll have to ask the image creator(s) for support or use the image from retropie.org.uk/download.
          kotif92 @mitu
          @mitu said in Help with retropie on retrodreamer cm4:
          My apologies. Will the official retropie image run on the retro dreamer cm4? If so, i will download it. Thank you
            mitu Global Moderator @kotif92
            @kotif92 Probably not without additional configuration. Judging by the name, it's probably based on a Compute Module 4 (CM4), which implies custom hardware, hence it might need additional drivers and/or configuration. If the vendor/creator of the hardware provides instructions on how to configure it, you can use it with the RetroPie base image.
