    [Solved]Samba Shares not working for me
    22 Posts 4 Posters 22.1k Views
    • plasmah77P
      plasmah77
      Samba shares question:
      Not a big deal but I would like to know. I for for reason cannot get samba shares to work for retropie. I do the //RETROPIE or //192.168.0.X and still can't connect to my pie. I'm on Windows 8.0.
      I can use Bitvise, Filezilla and Winscp perfectly fine to transfer my roms. So whats the deal with Samba Shares? I can't figure it out. Thanks
        BuZz administrators
        https://retropie.org.uk/forum/topic/3/read-this-first (eg retropie version etc - did you install from image or manually on top of raspbian)
        • plasmah77P
          plasmah77
          Sorry I installed from image version 3.8.1 on Pi3 using Windisk 32. SSH works fine.
            BuZz administrators
            Please do sudo apt-get update; sudo apt-get dist-upgrade from a terminal on the rpi - then reboot, and see if that makes a difference.
            Worth confirming the IP address also. Do you have any outbound firewall enabled on the windows machine ?
            • U
              UP4IT
              From Windows, have you tried \\retropie ?? The slashes are the other way round on Windows from Linux? :-)
                BuZz administrators
                oh yeh - didn't notice that - that is probably it :-)
                • U
                  UP4IT
                  Would be nice to hope it was that simple for a change :-)
                  • plasmah77P
                    plasmah77
                    Well I did what Buzz said in terminal and still don't work. But I just seen the // and lol I think you may be right I will try \ instead of //. I bet it was that. Cause I use Linux as well and would have never thought of that. Thanks guys appreciate all the help.
                    • EkstremeE
                      Ekstreme
                      This was an known Win 8 SMB security issue.. Check out a buddy of mine's blog: https://www.adamfowlerit.com/2013/05/26/unable-to-map-drives-from-windows-8/
                      • U
                        UP4IT @plasmah77
                        @plasmah77 let us know :-)
                        • U
                          UP4IT @Ekstreme
                          @Ekstreme let's hope it's the \\ v // :-) umm that doesn't look good as i typed it
                          • plasmah77P
                            plasmah77
                            Nope no worky :(
                            • EkstremeE
                              Ekstreme
                              can you ping the hostname? I guess you know the IP, so if you're client is windows (windows 8 you mentioned) it we definately be \hostname or \ipaddress
                              What is the error?
                              • plasmah77P
                                plasmah77
                                Yes I can ping the host name and it returns OK. My Pi's IP is 192.168.0.16. It says Unknown Error and gives an error code # when I try to connect with \\RETROPIE or \\192.168.0.16
                                • EkstremeE
                                  Ekstreme
                                  "#" is the error code?
                                  • plasmah77P
                                    plasmah77
                                    0x80004005
                                      BuZz administrators @plasmah77
                                      @plasmah77 I added backticks to your post to do inline code - otherwise text will not come out as you intended - see compose help when writing on the forum.
                                      • plasmah77P
                                        plasmah77
                                        Thanks BuZz
                                        • EkstremeE
                                          Ekstreme
                                          Make sure "Client for Microsoft Networks" is enabled on your network adaptor. If this is there and you've disabled secure negotiate, I have no idea sorry. Every time I've seen this it's secure negotiate option.
                                          Did you reboot after changing the secure negotiate setting?
                                          • plasmah77P
                                            plasmah77
                                            OK Client for Microsoft Networks was not there I just added it. Let me reboot brb
