    Dell Monitor - Goes into power saving mode when i turn on Rpi3b
    dell 2007fpbrpi3bdvitohdmi
    2 Posts 2 Posters 527 Views
      Stavros7575 0
      Hello my friends. I have a problem with an rpi3B connected to a dell monitor 2007FPb. Two days ago worked fine. Today i switched it on and it went into power save mode. After that it says "Out of range signal Cannot display the video mode, change computer display output to 1600x1200 60hz.
      I am reading all day, i have changed everything possible in the config.txt file but nothing. It shows a purple line on the left side and after that is entering in power save mode. I know that the sd card is working, i know that the pi is working i know that the monitor is working. Is there something i can do to fix that? Can you please help?
      *edit: After that i hooked up the pi on a different monitor, again nothing. But when i hooked it up on the first monitor it worked. But when i shut it down from the menu and turned it back on, again black screen and went to power saving mode.
      • exitkioskmodeE
        exitkioskmode
        "Entering Power Saving Mode" is actually an issue with the monitor and not the pi.
        why do I keep running into problems
