    Pi zero 2 with gpi case v-sync sound issue
    pi zero 2gpi caseretroarch
    7 Posts 2 Posters 972 Views
      Kpu4
      Hello. I think the problem is a gpi case and retroarch spicific. When I turn v-sync on the video is fine but audio cracks periodically. When I turn v-sync off the sound is fine but video starts to stutter. When I used recalbox, before retropie had a stable zero 2 release, in the retroarch options was a "Settings > Video > Output > set Vertical Refresh Rate" line where you could set refresh rate to 59.712hz and solve sound issues. But I don't see same video option in retropie-retroarch, only video driver selection and monitor index. Is it locked? Do I need to edit some configs to get more options?
        @Kpu4 said in Pi zero 2 with gpi case v-sync sound issue:
        You may need to enable Show Advanced Settings in the Settings -> User Interface menu and then re-open the RGUI.
        K 2 Replies Last reply Reply Quote 0
          Kpu4 @mitu
          @mitu it added few options but not the refresh rate. There is no info about this when I checked the web, like people use only recalbox with zero 2 and gpi case.
            This post is deleted!
              Kpu4 @mitu
              @mitu I made a few photos to make sure we understand each other.
              Thats how default video options menu looks in recalbox-retroarch and I think its what I need.
              And thats how retropie-retroarch video options menu looks with advanced settings enabled.
                The option is there, but it's disabled when Threaded Video is On - so if you want to change it, you need to disable Threaded Video (which is under Video).
                K 1 Reply Last reply Reply Quote 2
                  Kpu4 @mitu
                  @mitu thanks you, I hope it will help.
                  P.S. seems like it helped, enabling v-sync doesn't causes sound issues anymore.
