    HELP! I need img to pi 3 a +
    raspberrypi 3a+
    16 Posts 8 Posters 3.9k Views
    • N
      neo2216
      Good morning ! I need your help ! I can't find anywhere an image to use on my raspberry pi 3 a +! (I only saw that you have to do a process on a pi 3 B, and then pass it, but I DON'T HAVE A pi 3 b to do it). SOMEONE WHO HAS A PICTURE FOR THE pi 3 a + ??? thank you so much! I've been all over the internet and can't find anything.
      P.D: im sorry but my BAD ENGLISH, im from to ARGENTINA.
      sirhenrythe5thS onebitcpuO 2 Replies Last reply Reply Quote 0
        sleve_mcdichael
        The one on the downloads page is for all models of Pi3, isn't it?
        https://retropie.org.uk/download/
        https://github.com/RetroPie/RetroPie-Setup/releases/download/4.8/retropie-buster-4.8-rpi2_3_zero2w.img.gz
        N 1 Reply Last reply Reply Quote 1
        • sirhenrythe5thS
          sirhenrythe5th @neo2216
          @neo2216 yep, the one @sleve_mcdichael pointed to is the right image for your Pi3A+.
          Just install this one and enjoy!
          RetroRatio: 1.91
          Started Games beaten: 2,40%
          • N
            neo2216 @sleve_mcdichael
            @sleve_mcdichael Hello! Thanks for the reply! No, it doesn't work, and I started to investigate and it's because they are for 3 but 3 or 3 B, not for A, and those who could make it work in "A +" do it with a trick in which they record on a pi 3 b, and then they edit some files and record it, and just then they pass it on to a 3 A +. THE PROBLEM is that I DO NOT HAVE A PI 3 b to do that process.
            • N
              neo2216 @sirhenrythe5th
              This post is deleted!
                Are you sure you don't have a Pi 1 Model A+, in which case the Pi1/Zero image should be used ?
                What error do you get when booting the Pi ?
                • N
                  neo2216 @mitu
                  @mitu Hello! No, maybe the mistake is that they didn't read the title correctly haha. I don't have a pi 1a, it's a Pi3A+. THAT IS THE IMAGE I'm looking for and I can't get it. :(
                  retropieuser555R mituM 2 Replies Last reply Reply Quote 0
                  • retropieuser555R
                    retropieuser555 @neo2216
                    @neo2216 so when you flash the above download 2-3pi image to the sd card, what error are you getting?
                    Edit:- The bit about using a 3b into a 3a to proceed and get it working; is that from this below ETA Prime videos comments? I think they're referring to if you brought a 3b and you then brought a 3a and wanted to test you can do that process they outline. (This video is the one I mean:-
                    But in your case, you can just go ahead download the RetroPie version that is for pi 2, pi3 or pi zero 2 w, that version will work on any of the pi 3 variants and you should be up and running ok
                    Pi 5 4GB
                      mitu Global Moderator @neo2216
                      @neo2216 What's the error you're getting ? As previous posters said, the Pi2/3 is the image that should work.
                      Is the Raspbian image from raspberrypi.com working with your Pi ?
                      • N
                        neo2216 @retropieuser555
                        @retropieuser555 No, let's go again.
                        I HAVE A Pi 3A+. From what I read in many forums (INCLUDING THE VIDEO YOU SEND ME) there is no image for this board. IF I DOWNLOAD the official retropie 1/2/3/zero, IT DOESN'T WORK. It installs, but at the end of the installation (when you install it for the first time) an error appears saying "EMULATION STATION CRASHED!) if this your first boot of retropie, make sure you are using the correct image of your system. Probe downloading it from official retropie, and also with the automatic raspberry pi installer, both do the same. IF YOU SEE THE VIDEO; there it says that for it to work on a pi 3a+ you have to install it on a pi3b and then edit a file, and then pass the sd to pi 3a+.
                        BUT THERE IS NO OFFICIAL IMAGE FOR THE PI 3 A+.
                        that's why I'm doing this tread because I know that YES IT DOES go back to the 3a+, to see if someone has that image already "MANUALLY CORRECTED" to share it with me.
                        • N
                          neo2216 @mitu
                          wmarcioW 1 Reply Last reply Reply Quote 0
                          • wmarcioW
                            wmarcio @neo2216
                            @neo2216 said in HELP! I need img to pi 3 a +:
                            Then your question is resolved.
                              @neo2216 the Pi2/3 image is the right one. The video referenced is an old video (from 2018), from before RetroPie supported the board. The Pi2/3 images support the 3A+ since RetroPie 4.5.
                              ...an error appears saying "EMULATION STATION CRASHED!) if this your first boot of retropie
                              Ok, so this is the actual error. At the command prompt, run
                              emulationstation --debug
                              and post the log that the command produces. Same log can be found in $HOME/.emulationstation/es_log.txt - post the contents of this file. Do you have any controllers/keyboards connected to the board - can you add some info about them - what model/connection ?
                              Also, please don't repeat your replies to each user, once is enough since any participant in the topic gets notified of new replies to the topic.
                              • N
                                neo2216 @wmarcio
                                @wmarcio NO, because there are people with pi 3a+ using retropie, who do it with the method mentioned ABOVE. BUT the issue is that for that method you need a pi 3b to correct it and then pass it to the A+. That is why I consult here, in case someone HAS THE IMAGE ALREADY CORRECTED READY.
                                  Matt90 @neo2216
                                  @neo2216 Hola solucionaste el problema?. Conseguiste una imagen de Retropie que funcione en tu Raspberry 3A+. Yo tambien quiero comparme una Raspberry 3A+ para jugar videojuegos, pero no estoy seguro.Soy de Argentina
                                  Hello, did you solve the problem?. You got a Retropie image that works on your Raspberry 3A+. I also want to buy a Raspberry 3A+ to play video games, but I'm not safe. I'm from Argentina
                                  • onebitcpuO
                                    onebitcpu @neo2216
                                    @neo2216 if you cant get an image to run, you can also install retropie on the default raspberry pi os using these instructions:
                                    Install retropie in raspbian os
                                    This is how i have installed it.
