    Amiberry 5.1 controller mapping problem (since upgrading from 3.x)
    amiberry 5.0controller
    45 Posts 7 Posters 7.5k Views
    • DTEAMD
      DTEAM @DTEAM
      @DTEAM said in Amiberry 5.1 controller mapping problem (since upgrading from 3.x):
      new edit : I added my controller in the /opt/retropie/configs.hdmi/amiga/amiberry/conf/gamecontrollerdb.txt with the ppsspp method and nothing has changed.
      I did the same thing for /opt/retropie/configs.hdmi/all/retroarch/autoconfig/gamecontrollerdb_user.txt
      The mapping was incomplete and wrong.
      Can it be interference between retroarch.cfg and gamecontrollerdb_user.txt
        I don't think Amiberry looks there - it ships a gamecontrollerdb.txtin /opt/retropie/configs/amiga/amiberry/conf and it looks also for gamecontrollerdb_user.txtin the same location, so you might want to use the latter file to add your gamepad mapping.
        /opt/retropie/configs.hdmi/amiga/amiberry/conf/retroarch.cfg
        That's not the file I was asking - the controller's .cfg file should be in /opt/retropie/configs/all/retroarch-joypads.
        • DTEAMD
          DTEAM @mitu
          @mitu said in Amiberry 5.1 controller mapping problem (since upgrading from 3.x):
          Hi, here it is.
          /opt/retropie/configs/all/retroarch/retroarch-joypads/Teensyduino KeyboardMouseJoystick.cfg
          https://pastebin.com/jk7DGSEG
          New edit: I tried many things, but nothing works. I'm out of ideas. Do you know where is the file where we can select the gamepad. I would like to change CD32 pad to default, but it never saves my selection. it doesn't seem to be in amiberry.conf
          • DTEAMD
            DTEAM @DTEAM
            Solved!! In /opt/retropie/configs.hdmi/amiga/amiberry/conf/amiberry.conf , I modified:
            default_controller1=joy1
            default_controller2=joy2
            for
            default_controller1=joy0
            default_controller2=joy1
            For some reason, with Amiberry 5.X, it was joy 1 and joy 2 instead of joy0 and joy1.
            I'm doing test for the mouse
            default_mouse2=joy0 or joy1
            NEW EDIT: I think It's an error in the original .conf file, maybe it should be fixed. Another thing, my analog joystick is in reverse mode for left and right and also up and down. Is there an option to fix that?
            In order to have sound, I had to put default_soundcard=1 in /opt/retropie/configs.hdmi/amiga/amiberry/conf/amiberry.conf
            • DTEAMD
              DTEAM @DTEAM
              On Amiberry, it looks like I don't have access to all the buttons on my gamepad for CD32.
              Can someone do a test with Chambers Of Shaolin and tell me if he is able to punch and kick?
