    Amiberry - Using --model when launching
    amiberryemulators.cfgconfigure file
    2 Posts 2 Posters 402 Views
      mathan416
      Hey Everyone,
      Looking at emulators.cfg, when testing, manually, some of the command lines such as
      /opt/retropie/emulators/amiberry/amiberry.sh [put in a image name] --model CDTV
      /opt/retropie/emulators/amiberry/amiberry.sh [put in a image name] --model CD32
      Amiberry on RetroPie does not bring up the proper model with the appropriate ROMS, etc.
      I've ended up setting up my own configurations which work beautifully. i.e.
      amiberry-cd32 = "/opt/retropie/emulators/amiberry/amiberry_cd32.sh -config /opt/retropie/emulators/amiberry/conf/rp-CD32.uae %ROM%"
      Is there something missing the installation of Amiberry that updates/upgrades through RetroPie is missing?
      -Iain
        @mathan416 said in Amiberry - Using --model when launching:
        The entries in emulators.cfg are meant to be toggled manually, from the runcommand menu, by the user. They're not assigned automatically when you run a game.
        However, if you're using the default amiberry emulator (i.e. no model), then it will attempt to guess the model needed based on the filename launched.
