    Rasperry Pi 4 - Neogeo controls not working
    raspberrypineogeofbneo
    30 Posts 4 Posters 6.4k Views
      slooker
      I'm using RetroPie with fbneo-libretro.so. I don't seem to be able to use the controls.
      Right trigger for example is jump when I push it down, and shoot when I release it. Obviously that's not ideal. :)
      How do I setup my controls specifically for Neogeo? They work in every other emulator I've tried.
        sleve_mcdichael @slooker
        @slooker please provide some more details about your build as requested in https://retropie.org.uk/forum/topic/3/read-this-first
        lr-fbneo works for me without any additional configuration. Can we see the verbose log of a session with a NeoGeo game where the problem is occurring?
          slooker @sleve_mcdichael
          @sleve_mcdichael
          I've also noticed that I can't do anything after I go into the Neogeo menu after loading a game. I was going to see if I could configure the controller in there, but I load the quick menu and I can't move around in it or get out of it except by resetting the raspberry pi.
          Pi Model or other hardware: 4 (with 4gb ram)
          Power Supply used: PSU that came with canakit for raspberry pi 4
          RetroPie Version Used: 4.8
          USB Devices connected: usb keyboard, logitech mouse dongle
          Controller used: xbox one controller (times 2)
          Error messages received: (no messages, just controls don't work)
          Verbose log (if relevant):
          Guide used: no guide
          File:
          Emulator: neogeo
          Attachment of config files:  (configs) https://pastebin.com/bwgDNmgR
          How to replicate the problem:  install retropie, load up metalslug 1 (or 2) and try to play after configuring an xbox one controller in emulation station.
            @sleve_mcdichael Here is the verbose log: https://pastebin.com/85m5pFW0
              sleve_mcdichael
              @slooker the log looks okay, I think; it doesn't show any remaps in use, or any obvious errors that I can see. Can we see your neogeo/retroarch.cfg?
              /opt/retropie/configs/neogeo/retroarch.cfg
                @sleve_mcdichael
                It was in the original pastebin
                # Settings made here will only override settings in the global retroarch.cfg if
                placed above the #include line
                input_remapping_directory = "/opt/retropie/configs/neogeo/"
                  sleve_mcdichael
                  @slooker oh sorry I didn't realize that was a different link than the log. That looks normal too. As does your global config. I'm not sure what else to look for; hopefully someone else can pick this up and get you sorted.
                    @sleve_mcdichael Well bugger. I appreciate you taking the time to help! Thanks!
                      @slooker said in Rasperry Pi 4 - Neogeo controls not working:
                      For some reason, your gamepad is detected as keyboard (?):
                      [INFO] [udev]: Keyboard #0: "HOLDCHIP USB Gaming Keyboard" (/dev/input/event4).
                      [INFO] [udev]: Keyboard #1: "HOLDCHIP USB Gaming Keyboard System Control" (/dev/input/event5).
                      [INFO] [udev]: Keyboard #2: "HOLDCHIP USB Gaming Keyboard Consumer Control" (/dev/input/event6).
                      [INFO] [udev]: Keyboard #3: "HOLDCHIP USB Gaming Keyboard" (/dev/input/event7).
                      [INFO] [udev]: Keyboard #4: "Xbox Wireless Controller" (/dev/input/event1).
                      [INFO] [udev]: Keyboard #5: "" (/dev/input/js0).
                      Are you using a genuine Xbox One controller or is it a clone/3rd party controller ? Is it detected as gamepad on a PC or does it appear as a keyboard also ?
                        slooker @mitu
                        @mitu It's a genuine xbox one controller that works as a controller on my PC. I've got two of them connected, and they both work fine on PC?
                          @mitu said in Rasperry Pi 4 - Neogeo controls not working:
                          Ok, it's also detected as a controller. I guess the driver adds an extra key input so that's why is detected with a keyboard input.
                          [INFO] [udev]: Mouse #0: "Logitech M325" (REL) /dev/input/event0
                          [INFO] [udev]: Pad #0 (/dev/input/event1) supports 0 force feedback effects.
                          You can remap the buttons via the Core input remapping menu in RetroArch and re-arrange the buttons as you want.
                          If the controllers are connected via Bluetooth, I'd also recommend installing the xpadneo driver (it's included in RetroPie-Setup, you just need to install it from the drivers section). You may have to re-pair the controller and re-configure it in EmulationStation.
                            slooker @mitu
                            @mitu As soon as I open the Quick menu in a neogeo game, I can't move around the menu at all. I can't exit the menu with the controller OR keyboard. I usually end up having to ssh in and reboot. I'll try adding the xpadneo driver to see if that helps.
                              slooker @mitu
                              @mitu Looks like I already have xpadneo (Installed - via source). Is there something else I should be doing?
                                mitu Global Moderator @slooker
                                Unplug the keyboard ?
                                  slooker @mitu
                                  I unplugged the keyboard and completely rebooted. I still have weird controls and I can't move anything after opening up the quick menu. Here's my verbose log of this run: https://pastebin.com/u2hepqCb
                                    I'm not sure why the quick menu doesn't work - just for Neogeo games.
                                    FBneo added some input macros bound to L1/R2 and L2/R2, so that may explain why the triggers have actions associated. They can be disabled from the Controls sub-menu from RetroArch's quick menu, but if that's not working for you, I guess you can't change it.
                                    If you use only the keyboard, are you able to open (F1) and operate the quick menu ? Can you post the controller profile - there should be a .cfg file from /opt/retropie/configs/all/retroarch-joypads named Xbox Wireless Controller.
                                      slooker @mitu
                                      @mitu After plugging the keyboard back in and restarting emulation station, F1 does nothing at all when I push it on the keyboard.
                                      Here's my xbox wireless config though:
                                      $ more Xbox\ Wireless\ Controller.cfg
                                      input_device = "Xbox Wireless Controller"
                                      input_driver = "udev"
                                      input_enable_hotkey_btn = "10"
                                      input_r3_btn = "14"
                                      input_r_y_minus_axis = "-3"
                                      input_l_btn = "6"
                                      input_load_state_btn = "6"
                                      input_r_y_plus_axis = "+3"
                                      input_up_btn = "h0up"
                                      input_up_btn_label = "D-Pad Up"
                                      input_left_btn = "h0left"
                                      input_left_btn_label = "D-Pad Left"
                                      input_select_btn = "10"
                                      input_r2_axis = "-4"
                                      input_r_x_minus_axis = "-2"
                                      input_l_y_plus_axis = "+1"
                                      input_l_y_plus_axis_label = "Left Analog Y+"
                                      input_l_x_plus_axis = "+0"
                                      input_l_x_plus_axis_label = "Left Analog X+"
                                      input_right_btn = "h0right"
                                      input_right_btn_label = "D-Pad Right"
                                      input_l2_axis = "+5"
                                      input_l_x_minus_axis = "-0"
                                      input_l_x_minus_axis_label = "Left Analog X-"
                                      input_r_x_plus_axis = "+2"
                                      input_l3_btn = "13"
                                      input_r_btn = "7"
                                      input_save_state_btn = "7"
                                      input_l_y_minus_axis = "-1"
                                      input_l_y_minus_axis_label = "Left Analog Y-"
                                      input_y_btn = "3"
                                      input_x_btn = "4"
                                      input_menu_toggle_btn = "4"
                                      input_down_btn = "h0down"
                                      input_down_btn_label = "D-Pad Down"
                                      input_start_btn = "11"
                                      input_exit_emulator_btn = "11"
                                      input_b_btn = "0"
                                      input_b_btn_label = "A"
                                      input_reset_btn = "0"
                                      input_a_btn = "1"
                                      input_a_btn_label = "B"
                                        slooker @slooker
                                        So I was actually wrong about being able to navigate the quick menu in other systems.
                                        I can't navigate the quick menu in ANY system using the keyboard or controller.
                                        I've just never needed to in another system because the buttons work the way I expect them to. :/
                                          slooker @slooker
                                          Apparently the right and left bumper lets me move (3 or 4 lines at a time...) through the quick menu. So I can navigate the quick menu, just not with any precision. :)
                                            slooker @slooker
                                            Apparently after waiting ~5 seconds, the bumpers work, then everything works, as far as navigating the quick menu. Now I just have to figure out how to reset the controls for neogeo....
