    PS3 control on LR-PPSSPP
    ps3 controller
    2 Posts 2 Posters 456 Views
      cimbaklm
      Hello,
      I have an issue with my original PS3 controller which is not recognized in games for lr-ppsppp.
      Basically, I can use it in LR menu (which I can access via another pad) only with dpad (no analogically nor specific button like select or start).
      I tried to use it via PPSSPP and it works fine (I had to do a manual remap) but I'd like to use libretto for all my emulation station so I'd rather use lr.
      Pi Model or other hardware: PI4
      Power Supply used: original
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.8
      USB Devices connected:
      pi@retropie:~/RetroPie-Setup/tmp/build/controllermap $ lsusb
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 005: ID 413c:2003 Dell Computer Corp. Keyboard
      Bus 001 Device 004: ID 0079:0006 DragonRise Inc. PC TWIN SHOCK Gamepad
      Bus 001 Device 003: ID 0079:0006 DragonRise Inc. PC TWIN SHOCK Gamepad
      Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Controller used: 2 dragonrise (works fine) and 2 original PS3 BT connected controllers
      Error messages received: no error, just not works
      Verbose log (if relevant): none
      Guide used:
      I used this note https://retropie.org.uk/forum/topic/15577/ppsspp-controller-setup-guide-for-when-nothing-else-works
      But I saw that my device was already present in the file gamecontrollerdb.txt
      File: /opt/retropie/libretrocores/lr-ppsspp/assets/gamecontrollerdb.txt
      Emulator: lr-ppsspp
      Attachment of config files: please ask for any logs, I can upload, for now I can't see any error
      How to replicate the problem: PS3 controller with lr-ppsspp
      thanks for your help.
        @cimbaklm said in PS3 control on LR-PPSSPP:
        How exactly did you test this ? Did you start lr-ppsspp with only the PS3 controller(s) connected ? Are the Dragonrise controllers still present when you did the testing ?
        Please post a verbose log from starting a game with lr-ppsspp, on pastebin.com.
        That doesn't apply to the libretro core, any gamecontrollerdb related configurations apply only to the standalone emulator.
