    4.8 Emulationstation Problems
    troubleshooting
    4 Posts 4 Posters 706 Views
      jawsisra
      I updated to 4.8 today and I am now unable to play any games let alone use my system
      Pi Model: 4B+
      Power Supply used: Do not know the name of it. It has a switch to turn off the power
      RetroPie Version Used:4.8
      Built From: (Pre made SD Image on Rasberry Imager
      Controller used: Playstation Classic Controller
      Error messages received: Emulationstatuon has Crashed
      Attachment of config files: I do not know how to do this. if you can tell me how to pull the config files from the Micro SD Card I will do so.
      How to replicate the problem: Restart Emulationstation
      This is not the only issue Everytime I turn on the Pi I have to reput back in my controller configs for all Controllers
      And if I go into any settings I can no longer use the controller I just configed.
      C sirhenrythe5thS 2 Replies Last reply Reply Quote 0
        @jawsisra said in 4.8 Emulationstation Problems:
        Looks like EmulationStation cannot save the input configuration - is your sdcard full ? Which image did you use to install RetroPie and what version was it ?
          cdaters @jawsisra
          @jawsisra, have you checked your log files?
          Can you SSH into your RetroPie from a separate computer and start ES from the terminal window on that computer?
          As ES loads you can see in real-time in that SSH session any issues that ES might encounter as it is starting up before it gets to a point where it would display a video on your monitor or TV.
          • sirhenrythe5thS
            sirhenrythe5th @jawsisra
            is this the way you shut down retropie / the raspberry pi?
            RetroRatio: 1.91
            Started Games beaten: 2,40%
