    Script module Q - vars outside of functions?
    script module
    6 Posts 2 Posters 454 Views
      sleve_mcdichael
      I am working on a script module and I find myself repeating a lot of the same vars over and over again in my different functions. Is it okay to define them once outside of any function and then call them from within?
      Example:
      rp_module_id="mymodule"
      rp_module_flags="!all rpi"
      dir1="path/to/dir1"
      file2="path/to/file2.ext"
      function install_mymodule() {
          mkUserDir "$dir1"
      function configure_mymodule() {
          mv "$file2" "$dir1"
      ...instead of:
          local dir1="path/to/dir1"
          mkUserDir "$dir1"
          local file2="path/to/file2.ext"
          mv "$file2" "$dir1"
      ...if yes, what do I do with the initially-undefined var used in "for" loops, i.e.:
      local file
      for file in "$file1" "file2"; do
      Would I,
      1: still declare a local file inside each function where I need to use it?
      2: do an empty file="" (or file=()?) outside the functions with the other vars?
      3: just wing it and do for file in without declaring it anywhere, first?
        BuZz administrators @sleve_mcdichael
        @sleve_mcdichael for retropie modules we dont allow global vars apart from the module configuration ones.
          BuZz administrators
          If you need to share paths between functions you can deduplicate this by having a function which outputs the path.
            sleve_mcdichael @BuZz
            @BuZz said in Script module Q - vars outside of functions?:
            ...and then I'm calling that function from within the other function right? Something like:
            function _getpath1_mymodule() {
                echo "$path/to/file"
            function _getpath2_mymodule() {
                echo "/path/to/$other/file"
            function_a_mymodule() {
            path1="$(_getpath1_mymodule)"
            path2="$(_getpath2_mymodule)"
            function_b_mymodule() {
            ...this doesn't seem to save any lines, in fact it uses even more lines since I'm now defining the paths once in each function and once each in their own individual function. I guess the benefit of this method is, if I change the path later, I only have to change it in one place instead of in each function separately.
            Is that all roughly correct?
              @sleve_mcdichael yes. Have a look at existing scriptmodules as some use this already.
                @BuZz thanks, I see something like this in e.g. moonlight.sh.
                Do you have any thoughts or comments on the method I use here in function enable_ vs the method in disable_ and install_ (or, on anything else)? I did it this way in enable_ because I also need to process the files individually, while the other two do them all as a group in the "for" loop:
                #!/usr/bin/env bash
                # This file is part of The RetroPie Project
                # The RetroPie Project is the legal property of its developers, whose names are
                # too numerous to list here. Please refer to the COPYRIGHT.md file distributed with this source.
                # See the LICENSE.md file at the top-level directory of this distribution and
                # at https://raw.githubusercontent.com/RetroPie/RetroPie-Setup/master/LICENSE.md
                rp_module_id="bgm123"
                rp_module_desc="Straightforward background music player using mpg123"
                rp_module_help="Place your MP3 files in $datadir/bgm"
                rp_module_section="exp"
                function _autostart_bgm123() {
                    echo "$configdir/all/autostart.sh"
                function _bashrc_bgm123() {
                    echo "$home/.bashrc"
                function _onstart_bgm123() {
                    echo "$configdir/all/runcommand-onstart.sh"
                function _onend_bgm123() {
                    echo "$configdir/all/runcommand-onend.sh"
                function depends_bgm123() {
                    getDepends mpg123
                function install_bin_bgm123() {
                    local scriptname="bgm_vol_fade.sh"
                    local files=(
                        "$(_autostart_bgm123)"
                        "$(_bashrc_bgm123)"
                        "$(_onstart_bgm123)"
                        "$(_onend_bgm123)"
                    local file
                    cp "$md_data/$scriptname" "$md_inst"
                    chmod +x "$md_inst/$scriptname"
                    for file in "${files[@]}"; do
                        # preserve original file versions
                        if [[ -f "$file" && ! -f "$file.old.bgm123" ]]; then
                            cp "$file" "$file.old.bgm123"
                            chown $user:$user "$file.old.bgm123"
                        fi
                    done
                function disable_bgm123() {
                    local files=(
                        "$(_bashrc_bgm123)"
                        "$(_onend_bgm123)"
                    local file
                    # kill player now since .bashrc won't do it later
                    vcgencmd force_audio hdmi 0 >/dev/null
                    pgrep mpg123 >/dev/null && pkill mpg123
                        if [[ -f "$file" ]]; then
                            # backup file and attempt to remove any existing bgm config
                            cp -f "$file" "$file.bak"
                            chown $user:$user "$file.bak"
                            sed -i '/#bgm/d' "$file"
                            # if file is now empty, remove it
                            [[ ! -s "$file" ]] && rm -f "$file"
                        fi
                    done
                function remove_bgm123() {
                    disable_bgm123
                    remove_share_samba "bgm"
                    restart_samba
                function enable_bgm123() {
                    local fadescript="$md_inst/bgm_vol_fade.sh"
                    local autostart="$(_autostart_bgm123)"
                    local bashrc="$(_bashrc_bgm123)"
                    local onstart="$(_onstart_bgm123)"
                    local onend="$(_onend_bgm123)"
                    local file
                    disable_bgm123
                    for file in "$autostart" "$bashrc" "$onstart" "$onend"; do
                        touch "$file"
                        chown $user:$user "$file"
                    done
                    echo -e "$(echo -e 'while pgrep omxplayer >/dev/null; do sleep 1; done #bgm123\n(vcgencmd force_audio hdmi 1 >/dev/null; sleep 8; mpg123 -Z "'$datadir'/bgm/"*.[mM][pP]3 >/dev/null 2>&1) & #bgm123'; cat $autostart)" > "$autostart"
                    echo -e '[[ "$(tty)" == "/dev/tty1" ]] && (vcgencmd force_audio hdmi 0 >/dev/null; pkill mpg123) #bgm123' >> "$bashrc"
                    echo -e '"'"$fadescript"'" -STOP & #bgm123' >> "$onstart"
                    echo -e '(sleep 1; "'"$fadescript"'" -CONT) & #bgm123' >> "$onend"
                function configure_bgm123() {
                    [[ "$md_mode" == "remove" ]] && return
                    local share="$datadir/bgm"
                    mkUserDir "$share"
                    add_share_samba "bgm" "$share"
                    restart_samba
                    enable_bgm123
                function play_pause_bgm123() {
                    if pgrep mpg123 >/dev/null; then
                        su $user -c "$md_inst/bgm_vol_fade.sh &"
                    else
                        su $user -c "(vcgencmd force_audio hdmi 1 >/dev/null; sleep 1; mpg123 -Z $datadir/bgm/*.[mM][pP]3 >/dev/null 2>&1) &"
                    fi
                function next_track_bgm123() {
                function gui_bgm123() {
                    local cmd=(dialog --backtitle "$__backtitle" --cancel-label "Back" --menu "Choose an option." 22 86 16)
                    while true; do
                        local enabled=0
                        grep '#bgm123' "$configdir/all/autostart.sh" >/dev/null && enabled=1
                        local options=()
                        if [[ "$enabled" -eq 1 ]]; then
                            if pgrep emulationstatio >/dev/null; then
                                options+=(
                                    P "Play / pause"
                                    N "Next track"
                            fi
                            options+=(
                                1 "Enable background music (currently: Enabled)"
                        else
                            options+=(
                                1 "Enable background music (currently: Disabled)"
                        fi
                        local choice=$("${cmd[@]}" "${options[@]}" 2>&1 >/dev/tty)
                        if [[ -n "$choice" ]]; then
                            case "$choice" in
                                P)
                                    play_pause_bgm123
                                N)
                                    next_track_bgm123
                                1)
                                        disable_bgm123
                                        printMsgs "dialog" "Background music disabled."
                                    else
                                        enable_bgm123
                                        printMsgs "dialog" "Background music enabled."
                                    fi
                            esac
                        else
                            break
                        fi
                    done
                Edit:
                @sleve_mcdichael said in Script module Q - vars outside of functions?:
                I am seeing in the style guide that I should not do this when the variable is assigned by command substitution and that declaration and assignment should be in separate lines:
                    local autostart
                    local bashrc
                    local onstart
                    local onend
                    local file
