    NES30 Pro issue - 3.6
    nes30bluetooth
    5 Posts 4 Posters 5.6k Views
      PJROUSE
      Pi Model: Pi3
      RetroPie Version Used: 3.6
      Built From: SD card
      USB Devices connected: Keyboard
      Controller used: NES30 Pro
      I am a total NOOB but have (after much messing about) got my NES30 to pair with my retropie. If I connect either via bluetooth or USB the issue is the same.
      The controls map and work fine in the retropie front end, and I also get the yellow confirmation of the controller in use when I launch a ROM, but when the game loads, the controls dont work. For example if I play super marioworld on the SNES, the dpad works and the select button makes mario jump, but nothing else works. If I launch NHL hockey on the megadrive, nothing works at all (and this is the same on all other ROMS).
      I have updated the setup script and also updated the NES30 firmware to the latest, but the result is the same.
      My retroarch-joypads folder contains a single file called 8BitdoNES30Pro.cfg and is as per this image
      Please help?
      Paul
      • RionR
        Rion
        change
        input_driver = "udev"
        To
        input_driver = "sdl"
        I think i did read that somewhere on reddit.
        It's worth a try :)
        FBNeo rom filtering
        Mame2003 Arcade Bezels
        Fba Arcade Bezels
        Fba NeoGeo Bezels
        • RionR
          Rion
          Have a look at this tutorial
          And this one
          https://www.reddit.com/r/RetroPie/comments/49amv4/8bitdo_controllers_guide/
          FBNeo rom filtering
          Fba Arcade Bezels
          Fba NeoGeo Bezels
            cdoss
            Hi,
            Did you ever get this working? This describes my problem exactly and I've spent hours scouring the internet for a solution. The above suggestion (Changing input driver) was unsuccessful.
              BuZz administrators @cdoss
              @cdoss Start a new topic (and read this first https://retropie.org.uk/forum/topic/3/read-this-first)
