    First boot rasperry pi 400 with Sony PS4 controller
    pi 400sonyps4 controller
    2 Posts 2 Posters 381 Views
    • N
      niwi
      Hi!
      Latest Retropie image - first boot, rasperry pi 400 with Sony PS4 controller (connected with USB cable)
      Status "No Gamepads detected"
      Any tips how to continue?
      Should the PS4 controller be discovered at first start?
      Do I need to do some configuration first , command line?
      Regards
      Jhw
        @niwi said in First boot rasperry pi 400 with Sony PS4 controller:
        Yes. Check the cable - it may be faulty or allows only charging (and no data communcation). If you have a PC available, check if the cable+controller are detected there.
