    Controller input is not registering after using RetroArch menu
    retroarchcontrollerno inputout of focus
    1 Posts 1 Posters 317 Views
      red2blue
      Running a RPi4 with RetroPie 4
      There's a 75% chance when I open RetroArch in any Libretro emulator and then close the menu my controller is no longer active. Inputs no longer work, until I hit another hotkey like Hotkey + L1 for example. When I use this combo, the controller inputs are back in focus and work again.
      Then when that happens and if I go into RetroArch menu, the controller inputs lose focus again but this time in the menu. So I have to hit another hotkey combo for it to retain its focus.... it makes zero sense.
      The per system retroarch configs are using the default config, I double checked this to make sure the input remapping is there and its all correct.
      Anyone know how to fix this issue?
