    Onscreen Gear Shifter Visibility Options
    gear shiftshifterhigh lowonscreen
    3 Posts 3 Posters 530 Views
      Red732
      Does anyone know how to remove the onscreen gear selection from games like Pole Position? I’ve seen it before, but I can’t remember where the config is.
      dankcushionsD roslofR 2 Replies Last reply Reply Quote 0
      • mituM mitu moved this topic from Projects and Themes on
        dankcushions Global Moderator @Red732
        @Red732 if it's an option it will either be here: https://retropie.org.uk/docs/lr-mame2003/#service-menu or here: https://retropie.org.uk/docs/lr-mame2003/#dip-switches
        (you don't say what emulator you're using so i'm guessing)
        • roslofR
          roslof @Red732
          @Red732 said in Onscreen Gear Shifter Visibility Options:
          Weird that I was just playing with this on Monday...
          Complimenting what @dankcushions provided, and using Pole Position with any version of MAME other than 2003-plus:
          • Hit TAB on a keyboard to toggle the MAME menu
          • Select Video Options
          Then, depending on which version of MAME you're using:
          For lr-mame2003
          • Select Dip Switches
          • Set "Display Shift" from On to Off
          For lr-mame2010 - lr-mame2016:
          • Select either "Standard (4:3) or Pixel Aspect (8:7)
          For lr-mame 0.222 and below:
          • Select one of the "Screen 0" options instead of the default "Shifter-R" option.
          For lr-mame newer than 0.222:
          • Select "Screen #0"
          • Then select one of the "Screen 0" options instead of the default "Shifter-R" option.
          For the bleeding edge versions of lr-mame, there are some newer video options that allow the shifter to be off the screen as another option.
