    Custom System Order
    system orderxmlorderes system
    3 Posts 2 Posters 455 Views
      theboundlesssky
      I'm having some issues getting EmulationStation to read the custom es_systems.cfg file.
      Here is the es_systems.cfg file that I created: https://pastebin.com/U2BNitwG
      I've edited the files in
      /etc/emulationstation/es_systems.cfg
      /home/pi/.emulationstation/es_systems.cfg
      I've rebooted the system several times, and also tried changing themes, but nothing seems to work on re-ordering the systems.
      Note: I do have the favorites collection enabled
      Anything else I should do or try?
        sleve_mcdichael @theboundlesssky
        @theboundlesssky not sure where this setting is in the GUI but if you check your es_settings.cfg I think you'll find:
        <bool name="SortAllSystems" value="true" />
        Change this to "false" and restart ES. Your config works for me, but not with that setting active:
        (SortAllSystems false):
        (I don't have anything in mame or fba folders so those aren't shown here.)
        (SortAllSystems true):
        T 1 Reply Last reply Reply Quote 1
          theboundlesssky @sleve_mcdichael
          @sleve_mcdichael Thanks! That was exactly the issue I was facing!
