    Does Megumi Rescue (Sega Master System) work on anything?
    master systemsmsplusgxgenesisplus-gxfbneosms
    2 Posts 2 Posters 385 Views
      JimmyFromTheBay
      I thought I'd check out this port now the coin-op works in MAME, but nothing seems to run it. Picodrive loops back to the title screen when you press the fire button, SMSPlus-GX starts the game but no movement controls work (the fire button does), and GearSystem loads it but nothing does anything on the title screen.
      FBNeo-SMS gets closest - the game starts but the controls are totally wonky. Right and left are back to front and you can't move into the left-hand half of the screen.
      Apparently Megumi Rescue was one of only four games to require the SMS paddle controllers, which I didn't even know existed. The only SMS emulator I can find with explicit paddle support is GenesisPlus-GX, but that won't boot the game even if I force it to run as a Japanese Master System. (SMSPlus-GX, weirdly, doesn't have the Master System controller options that GP-GX does.)
        barbudreadmon @JimmyFromTheBay
        @JimmyFromTheBay said in Does Megumi Rescue (Sega Master System) work on anything?:
        The arcade version works properly in FBNeo, i don't know about the sms version (probably nobody tried it), i'll try to take a look soon.
