    Shutdown circuit advice
    mausberryshutdown script
    3 Posts 2 Posters 621 Views
      kr55
      Hi I recently got a mausberry shutdown circuit for raspberry pi 4b. The circuit came with an onboard switch so I thought I'd test it with that before soldering a slide switch for my build.
      However after installing the setup script and connecting gpio pins 23 and 24 as instructed nothing happens in emulationstation when the switch is toggled. Would anyone know if extra config is needed for that to work please?
      AshpoolA 1 Reply Last reply Reply Quote 0
      • AshpoolA
        Ashpool @kr55
        @kr55 @cyperghost s Shutdownscript supports the Mausberry
          kr55 @Ashpool
          @Ashpool thanks for the pointer :)
          Got it working using that script.
          If it helps anyone else my /opt/retropie/configs/all/autostart.sh file looks like:
          sudo /home/pi/RetroPie/scripts/multi_switch.sh --mausberry & emulationstation #auto
          (All on one line in the file)
          I suspect my missing piece with the 'stock' mausberry install script was adding it to the autostart file, but this alternative script works so will stick with it. 👍
