    Shutdown by switch work, but shutdown by menu give a reboot
    switchshutdown
    1 Posts 1 Posters 340 Views
      MarCologne
      I have installed completely new the latest image of RetroPie and then install the drivers of the 1st version of ControlBlock. That works in general. All buttons can be used as well as the hardware switch to shutdown the system.
      In the RetroPie menu I can also use the point "Shut down system" or similar but then the system reboots.
      I've had an old installation in the past, where the sd card had a failer, because of that the new installation. With the of installation there it works good. When selecting "Shot down system" the system shut down...
      Is there something to configure for that?
