    I lost my Retro-pie Settings/Options please help
    retro pie helpretropie issueretropie-setup
    13 Posts 2 Posters 1.4k Views
      Retrodade
      I can't even tell you what happened
      but when I try to enter anything in retro pie settings, I get this...
      "ges.sh: line 900:
      Module
      is missing valid rp_nodule_id
      Module
      is missing valid rp_module_desc
      mod_idx: bad array subscript"
      Then it boots back to ES menu. nothing else is affected on my image, how can i get settings to load again?
      What do I need to do?
      Thanks for helping!
        "ges.sh: line 900:
        You've added the ges.sh file, is probably what happened. Remove the file and try again.
          Retrodade @mitu
          @mitu i have done a search for this file in retro-pie set up, the search doesn't find it
          not sure of any other way to locate it
            Maybe you mis-spelled the error and it's actually:
            retropie_packages.sh: line 900:
            Module
            Module
            You added a file that's not part of RetroPie-Setup and it's not compatible with the RetroPie version you're using - this is what the error says, basically.
            Run the following command from the terminal:
            cd RetroPie-Setup
            git status
            and post the output.
              Retrodade
              @mitu said in I lost my Retro-pie Settings/Options please help:
              git status
              pi@retropie:~ $ cd RetroPie-Setup
              pi@retropie:~/RetroPie-Setup $ git status
              On branch master
              Your branch is up to date with 'origin/master'.
              Changes not staged for commit:
              (use "git add <file>..." to update what will be committed)
              (use "git checkout -- <file>..." to discard changes in working directory)
                  modified:   retropie_packages.sh
                  modified:   retropie_setup.sh
                  modified:   scriptmodules/emulators/atari800.sh
                  modified:   scriptmodules/libretrocores/lr-bsnes.sh
                  modified:   scriptmodules/libretrocores/lr-mess.sh
                  modified:   scriptmodules/libretrocores/lr-stella.sh
                  modified:   scriptmodules/libretrocores/lr-yabause.sh
              Untracked files:
              (use "git add <file>..." to include in what will be committed)
                  generate-desired-systems.sh
                  generate-systems-lr-mess_mame-2v1-ext.sh
                  generate-systems-lr-mess_mame-2v1.sh
                  generate-systems-lr-mess_mame-2v2-ext.sh
                  generate-systems-lr-mess_mame-2v2.sh
                  generate-systems-lr-mess_mame-2v3-ext.sh
                  generate-systems-lr-mess_mame-2v3.sh
                  generate-systems-lr-mess_mame-2v4-ext.sh
                  generate-systems-lr-mess_mame-2v4.sh
                  get-cheats-artwork-overlays.sh
                  packages.sh
                  scriptmodules/emulators/actionmax.sh
                  scriptmodules/emulators/amiberry/
                  scriptmodules/emulators/b-em-allegro4.sh
                  scriptmodules/emulators/b-em-pico-pi.sh
                  scriptmodules/emulators/elkulator.sh
                  scriptmodules/emulators/gearboy.sh
                  scriptmodules/emulators/gsplus-rp-share.sh
                  scriptmodules/emulators/kat5200.sh
                  scriptmodules/emulators/mpv.sh
                  scriptmodules/emulators/openbor.sh
                  scriptmodules/emulators/p2000t.sh
                  scriptmodules/emulators/pico8.sh
                  scriptmodules/emulators/pokemini.sh
                  scriptmodules/emulators/supermodel-mechafatnick.sh
                  scriptmodules/emulators/supermodel-svn.sh
                  scriptmodules/libretrocores/install-all_in1-cmd.sh
                  scriptmodules/libretrocores/install-apple2gs-cmd.sh
                  scriptmodules/libretrocores/install-apple2gs-from-mamedev-system-apple2g        s_-sl7_cffa2-hard1.sh
                  scriptmodules/libretrocores/install-bbcb-from-mamedev-system-bbcb-flop1.        sh
                  scriptmodules/libretrocores/install-classich-cmd.sh
                  scriptmodules/libretrocores/install-electron-cmd.sh
                  scriptmodules/libretrocores/install-electron-from-mamedev-system-electro        n_-exp_plus3,bios=dfs210-flop.sh
                  scriptmodules/libretrocores/install-electron-from-mamedev-system-electro        n_-exp_plus3-flop.sh
                  scriptmodules/libretrocores/install-electron-from-mamedev-system-electro        n_auto_x2aTAPECHAINx22x22-cass.sh
                  scriptmodules/libretrocores/install-electron-from-mamedev-system-electro        n_auto_x2aTAPEx2aRUN-cass.sh
                  scriptmodules/libretrocores/install-gameandwatch-cmd.sh
                  scriptmodules/libretrocores/install-jakks-cmd.sh
                  scriptmodules/libretrocores/install-konamih-cmd.sh
                  scriptmodules/libretrocores/install-nes-cmd.sh
                  scriptmodules/libretrocores/install-nes-from-mamedev-system-nes_datach-c        art2.sh
                  scriptmodules/libretrocores/install-odyssey2-cmd.sh
                  scriptmodules/libretrocores/install-odyssey2-from-mamedev-system-odyssey        2-cart.sh
                  scriptmodules/libretrocores/install-samcoupe-cmd.sh
                  scriptmodules/libretrocores/install-samcoupe-from-mamedev-system-samcoup        e_auto_boot-flop1.sh
                  scriptmodules/libretrocores/install-shooter-cmd.sh
                  scriptmodules/libretrocores/install-tigerrz-cmd.sh
                  scriptmodules/libretrocores/install-tvc64-cmd.sh
                  scriptmodules/libretrocores/install-tvc64-from-mamedev-system-tvc64_-exp        1_hbf-flop1.sh
                  scriptmodules/libretrocores/install-zx81-cmd.sh
                  scriptmodules/libretrocores/install-zx81-from-mamedev-system-zx81_auto_j        x22x22-cass.sh
                  scriptmodules/libretrocores/lr-daphne.sh
                  scriptmodules/libretrocores/lr-fceumm-mod.sh
                  scriptmodules/libretrocores/lr-flycast-new.sh
                  scriptmodules/libretrocores/lr-freej2me.sh
                  scriptmodules/libretrocores/lr-lowresnx.sh
                  scriptmodules/libretrocores/lr-mame2003_midway.sh
                  scriptmodules/libretrocores/lr-mess-jaguar.sh
                  scriptmodules/libretrocores/lr-mess-p2000t.sh
                  scriptmodules/libretrocores/lr-pocketcdg.sh
                  scriptmodules/libretrocores/lr-prboom-system.sh
                  scriptmodules/libretrocores/lr-puae2021.sh
                  scriptmodules/libretrocores/lr-yabasanshiro/
                  scriptmodules/ports/add-ext-repos.sh
                  scriptmodules/ports/add-mamedev-systems.sh
                  scriptmodules/ports/amphetamine.sh
                  scriptmodules/ports/b-em-pico_pi.sh
                  scriptmodules/ports/barrage.sh
                  scriptmodules/ports/bermudasyndrome.sh
                  scriptmodules/ports/bloboats.sh
                  scriptmodules/ports/box86winef1spiritremake.sh
                  scriptmodules/ports/box86winegooniesremake.sh
                  scriptmodules/ports/box86winemogremake.sh
                  scriptmodules/ports/box86wineroadfighterremake.sh
                  scriptmodules/ports/breaker.sh
                  scriptmodules/ports/burgerspace.sh
                  scriptmodules/ports/chocolate-doom-system.sh
                  scriptmodules/ports/chocolate-doom.sh
                  scriptmodules/ports/chromium.sh
                  scriptmodules/ports/corsixth.sh
                  scriptmodules/ports/crack-attack.sh
                  scriptmodules/ports/crispy-doom-system.sh
                  scriptmodules/ports/crispy-doom.sh
                  scriptmodules/ports/deadbeef.sh
                  scriptmodules/ports/devilutionx.sh
                  scriptmodules/ports/download_legal_stuff.sh
                  scriptmodules/ports/easyrpgplayer.sh
                  scriptmodules/ports/firefox-esr.sh
                  scriptmodules/ports/fofix.sh
                  scriptmodules/ports/freeciv.sh
                  scriptmodules/ports/freedink.sh
                  scriptmodules/ports/freesynd.sh
                  scriptmodules/ports/funnyboat.sh
                  scriptmodules/ports/gamemaker.sh
                  scriptmodules/ports/ganbare.sh
                  scriptmodules/ports/goonies.sh
                  scriptmodules/ports/hcl.sh
                  scriptmodules/ports/heboris.sh
                  scriptmodules/ports/hurrican.sh
                  scriptmodules/ports/ikemen_go.sh
                  scriptmodules/ports/kaiten-patissier-cs.sh
                  scriptmodules/ports/kaiten-patissier-ura.sh
                  scriptmodules/ports/kaiten-patissier.sh
                  scriptmodules/ports/kodi-extra.sh
                  scriptmodules/ports/kweb.sh
                  scriptmodules/ports/lbreakout2.sh
                  scriptmodules/ports/lgeneral.sh
                  scriptmodules/ports/lmarbles.sh
                  scriptmodules/ports/ltris.sh
                  scriptmodules/ports/manaplus.sh
                  scriptmodules/ports/mog.sh
                  scriptmodules/ports/netsurf.sh
                  scriptmodules/ports/nkaruga.sh
                  scriptmodules/ports/nxengine.sh
                  scriptmodules/ports/openbor-v6510-RPi4.sh
                  scriptmodules/ports/openjazz.sh
                  scriptmodules/ports/openjk_jo.sh
                  scriptmodules/ports/openjk_jo.sh.1
                  scriptmodules/ports/openxcom.sh
                  scriptmodules/ports/pingus.sh
                  scriptmodules/ports/prboom-plus.sh
                  scriptmodules/ports/pydance.sh
                  scriptmodules/ports/rawgl.sh
                  scriptmodules/ports/reminiscence.sh
                  scriptmodules/ports/rickyd.sh
                  scriptmodules/ports/roadfighter.sh
                  scriptmodules/ports/rocksndiamonds.sh
                  scriptmodules/ports/rott-darkwar.sh
                  scriptmodules/ports/rott-huntbgin.sh
                  scriptmodules/ports/sdl-bomber.sh
                  scriptmodules/ports/seahorse.sh
                  scriptmodules/ports/shiromino.sh
                  scriptmodules/ports/sm64ex.sh
                  scriptmodules/ports/sorr.sh
                  scriptmodules/ports/supertransball2.sh
                  scriptmodules/ports/texmaster2009.sh
                  scriptmodules/ports/tinyfugue.sh
                  scriptmodules/ports/ulmos-adventure.sh
                  scriptmodules/ports/vgmplay.sh
                  scriptmodules/ports/vorton.sh
                  scriptmodules/ports/warmux.sh
                  scriptmodules/ports/weechat.sh
                  scriptmodules/ports/wizznic.sh
                  scriptmodules/ports/xash3d-fwgs.sh
                  scriptmodules/ports/zeldansq.sh
                  scriptmodules/ports/zeldapicross.sh
                  scriptmodules/run_mess.sh
                  scriptmodules/supplementary/add-ext-repos.sh
                  scriptmodules/supplementary/add-mamedev-systems-0238.sh
                  scriptmodules/supplementary/add-mamedev-systems-0240.sh
                  scriptmodules/supplementary/add-mamedev-systems.sh
                  scriptmodules/supplementary/bezelproject.sh
                  scriptmodules/supplementary/download_legal_stuff.sh
                  scriptmodules/supplementary/fun-facts-splashscreens.sh
                  scriptmodules/supplementary/golang-1.17.sh
                  scriptmodules/supplementary/joystick-selection.sh
                  scriptmodules/supplementary/screenshot.sh
                Retrodade
                I see this...does this help? how can i re-ad them if it's what I'm
                needing?
                /home/pi/RetroPie-Setup/scriptmodules/packages.sh: line 900: __mod_idx: bad array subscript
                Module is missing valid rp_module_id
                Module is missing valid rp_module_desc
                  mitu Global Moderator @Retrodade
                  @Retrodade said in I lost my Retro-pie Settings/Options please help:
                  Sort of, I can see you have lots of modified/added files which indicate a heavily customized installation. Did you install the extra ports/emulators yourself or used a pre-made image ?
                  how can i re-ad them if it's what I'm needing?
                  Not sure I understand - to re-add what, exactly ?
                    Retrodade
                    I added the FollyMaddy Retropie-Share to it which has a lot of emus
                    all when fine till it had another retropie extras of sorts ( Inside the FollyMaddy) went to install it, that and got booted out of set up sadly
                    hoping this can be fixed
                      Retrodade @mitu
                      @mitu readd the missing files its saying it can find find? or is there something else i can do?
                        It's not complaining about missing files, but missing lines. As I said before
                        Maybe, which image did you use for the initial installation ?
                          Retrodade @mitu
                          @mitu my own we built this from a base install past 2 plus years
                          and thank you for your help!
                          once fixed I'm backing this up
                            I was actually interested by the RetroPie version used for the installation, but 2 years seems recent enough. The easiest way to recover your RetroPie-Setup installation is to rename the folder and pull the latest version. Run, from the terminal command prompt:
                            cd $HOME
                            mv RetroPie-Setup RetroPie-Setup.saved
                            git clone --depth 1 https://github.com/RetroPie/RetroPie-Setup/
                            You can then proceed and add back @Folly 's extra repository. The issue you have is probably from installing @zerojay's extras repository, which I don't think it's compatible with RetroPie current. You can try out @ExarKunIv 's extras repo (https://github.com/Exarkuniv/RetroPie-Extra/), which is compatible with RetroPie's current version and contains most of the scripts from @zerojay's older repo.
                              Retrodade @mitu
                              @mitu I DO NOT KNOW how to THANK YOU!
                              I know wife and i had made this image together for 2 years
                              and in a blink i messed it up i was so afraid to tell her lol
                              I can't believe it is back loading!
                              took your advice and went with the newer extras
                              I truly want to thank you kindly for your time
                              now i can back this up and have a deep breath lol
