    Bluetooth input lag from controller
    bluethooth issucontroller lagps4 controllerhelp joystick
    3 Posts 3 Posters 2.0k Views
    • W
      w.ekapak
      Pi Model or other hardware: 3b+
      RetroPie Version Used (4.8):
      Built From: (SD image)
      Controller used:dualshock for ps 4
      There is no delay from the wireless keyboard; there is only a delay from the controller.
      Genos98G 1 Reply Last reply Reply Quote 0
      • windgW
        windg
        RetroPie wiki have some steps to try if you have input lag with bluetooth controller: https://retropie.org.uk/docs/Bluetooth-Controller/
        • Genos98G
          Genos98 @w.ekapak
          @w-ekapak I also have delay and even disconnecting issues with ds4 at times. I solved it by using an 8bitdo bluetooth adapter.
