    Setting up plex and retropie.
    help retropieplex & retropiesetup
    7 Posts 5 Posters 3.7k Views
      maxx.ryno
      Hi not new to emulation, but new to retropie setup, easy premise I have a 27" bartop setup, I am after help on if it is possible to set it up the following configuration:
      Currently The MicroSD is Blank (256 gb) , I have a raspberry pi 4 with 2 gb and built in wifi. I would like to be able to run retropie and plex (or other media player). My main Desktop has all the roms but no card reader and I would like to be able to send the roms to the MicroSD via wifi if possible. is there a guide to do this or can someone give me instructions, thanks. I do have access to a laptop with a card reader but this does not contain my 200gb of roms for transfer.
      sirhenrythe5thS DarksaviorD 2 Replies Last reply Reply Quote 0
      • sirhenrythe5thS
        sirhenrythe5th @maxx.ryno
        @maxx-ryno i transfer all the roms via wifi by using a smartphone, so i guess it will work with any PC as well.
        I just open a file commander, mark the roms and copy them to the rom-folders on the pi by choosing "local network/[IP of the Pi]/roms/[system rom_folder]".
        It should be just as easy as this with a PC.
        RetroRatio: 1.88
        Started Games beaten: 2,47%
        Site Rank: 4382/93743 ranked users (TOP 4.76%)
        Last seen in [The Legend of Zelda: Lost in Time (HACK) [N64], exploring Hyrule at Night]
        • windgW
          windg
          Check RetroPie docs, you will find all the available options: https://retropie.org.uk/docs/Transferring-Roms/#transferring-roms
          • DarksaviorD
            Darksavior @maxx.ryno
            @maxx-ryno I don't believe there's a plex client available that will work alongside retropie. You can try installing kodi and then install the plexkodiconnect addon so it can access your plex server.
            I don't have kodi installed on my pi but it's on other devices .I also install the embuary skin.kodi embuary.jpg
            M 2 Replies Last reply Reply Quote 1
              maxx.ryno @Darksavior
              @Darksavior Thanks, the media player doesn't have to have any sort of client availabilty as I can send the media straight to the MicrOSD card I assume. So I just need a player > any help?
                mitu Global Moderator @maxx.ryno
                @maxx-ryno said in Setting up plex and retropie.:
                Just like @Darksavior said - install Kodi.
                  @Darksavior AWESOME DUDe thankyou
