    Problem with Redream saving (SOLVED)
    redream
    3 Posts 2 Posters 1.5k Views
      Retro Arcade Fan
      Could someone please tell me the "correct" way to save control setups in Redream on the pi? Some games use the d-pad for movement. Some use the left analog. So the joystick has to be remapped. But every time I make changes to one game, it saves that for every game using Redream. So I think I'm doing it wrong. Appreciate the help. Thank you.
      • lostlessL
        lostless @Retro Arcade Fan
        @Retro-Arcade-Fan I don’t think redream can have per game configs. I know lr-flycast can (or any other retroarch emulator)
          Retro Arcade Fan @lostless
          @lostless Thanks. I actually figured it out. There's a custom config setting on the bottom left. If you select it for every game, it won't affect others. Just never noticed it before!
