    Running Shovel Knight on Pi 4 (Seg Fault)
    shovelknight
    3 Posts 3 Posters 315 Views
    • StonedEdgeS
      StonedEdge
      Hi guys,
      I'm trying to get up and running ShovelKnight from EmulationStation.
      Have added this script to /home/pi/RetroPie/ports however am getting this error. Would anyone be able to help me understand where I'm going wrong? Have installed box86 through Pi Apps.
      #!/bin/bash
          --evdev /dev/input/event0 \
          --silent \
          --detach-kernel-driver \
          --force-feedback \
          --deadzone-trigger 15% \
          --deadzone 4000 \
          --axismap -y1=y1 \
          --mimic-xpad \
          --evdev-absmap ABS_X=x1,ABS_Y=y1 \
          --evdev-keymap BTN_EAST=a,BTN_SOUTH=b,BTN_WEST=x,BTN_NORTH=y,BTN_Z=lb,BTN_C=rb,BTN_TL=tl,BTN_TR=tr,BTN_THUMBL=guide,BTN_SELECT=back,BTN_START=start,BTN_DPAD_DOWN=du,BTN_DPAD_UP=dd,BTN_DPAD_LEFT=dl,BTN_DPAD_RIGHT=dr \
      cd /home/pi/RetroPie/roms/ports/ShovelKnight/32
      sudo box86 ShovelKnight
      sudo killall xboxdrv
      Error located here:
      https://imgur.com/cSoZZHb
      Check out my build logs below:
      Wii SPii (Wii in a GBA SP Shell)
      https://bitbuilt.net/forums/index.php?threads/the-wii-spii.3347/
      Retro Lite CM4
      https://bitbuilt.net/forums/index.php?threads/retro-lite-cm4-a-stonededge-and-dmcke5-collaboration.3934/
        sleve_mcdichael
        sudo box86: are you supposed to have to use sudo here, or is that just something you're doing because you've seen it before in other places that aren't this?
        "Error: /home/pi/RetroPie/roms/ports/ShovelKnight/32/ShovelKnight is not an executable file."
        If it's just a matter of permissions, you can set the executable flag with:
        chmod +x /home/pi/RetroPie/roms/ports/ShovelKnight/32/ShovelKnight
          Not sure how it's related to RetroPie, seems more of a box86 issue. Is the executable you're trying to run a Linux executable ?
