    Raspberry pi 4 no audio
    pi4 audio
    3 Posts 2 Posters 619 Views
      toughjiggy
      Since i setup dual lcd and tv displays the sound for the opening splashscreen cuts out after 4 seconds and there is no sound in the menu or gameview where you see the videopreviews however when i plug and external speaker in to the headphone jack of the pi there is sound when i load a game but still no sound in the menu.ive tried rasp config to change source to hdmi 01.ive also tried the terminal config.txt and deleting the hashtag before hdmi_group2 with still no luck
        Please add some info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        Did you change also the Audio settings in EmulationStation's menu ?
          toughjiggy @mitu
          @mitu hi im using a pi4 2gb
          Version 4.8.2
          Original pi power plug
          Built on 128gb sd card
          My audio settings are
          Audio card DEFAULT
          audio device HDMI
          enable navigation soubds ON
          enable video audio ON
          Omxplayer BOTH
