    Another gameboy zero project RaspiBoy
    8 Posts 7 Posters 3.5k Views
      PaddleStroke
      It might (or not) interest you ! :)
      cyperghostC 1 Reply Last reply Reply Quote 7
        Very nicely done! I wonder why the case requires injection molding instead of just normal 3D printing, but having the shoulder buttons on the back makes it look like it's really comfortable to hold.
          PetroRie
          Looks AWESOME! Well done!
            cyperghost @PaddleStroke
            @PaddleStroke Can you please tell me how you get sound working? Did you usw rpi-wire?
            • EkstremeE
              Ekstreme
              Awesome design. I love the shoulder buttons moulded into the back of the case.
                edmaul69 @obsidianspider
                @obsidianspider injection molding looks 1000 times better. I will never buy a 3d printed case. It looks terrible in my opinion.
                  PaddleStroke @cyperghost
                  @cyperghost there's a guide on adafruit for audio output :
                  https://learn.adafruit.com/adding-basic-audio-ouput-to-raspberry-pi-zero
                  I'm glad that you guys like it, please share it :)
                  I am working on a custom complementary PCB to make the build even more easy to make. With the crowdfunding version there will be no need to solder anything ! :)
                  And yes injection molding because 3Dprint does not look very good, the prototype I had to use selective laser sintering to have a good print. And it cost a lot, about 150$ for both casing!
                    Aceisback
                    Will be selling just the case?
