    RetroPie running as a docker container on x86_64
    dockersetupcontrollerretroarchscripts
    7 Posts 4 Posters 15.6k Views
    • N
      nwildner
      Hi All.
      I'm working in a little project of running RetroPie inside a container. I aware it is NOT supported, but I have decided to do this because
      • My machine runs with strict Secure Boot and Luks configurations
      • Not using Ubuntu as my desktop disto
      • Dual-boot would be much of a pain because, additional data should be signed on my Secure Boot madness + my ESP partition is way too slim to hold boot data from other OS.
      • RetroPie will provide me some nice "must have" like auto configuring Retroarch controllers when configuring input inside EmulationStation so, I don't have to bother configuring stuff in multiple places.
      That's why I decided to try Docker. So far, this is the result: https://github.com/nwildner/retropie-docker
      A dockerfile that builds RetroPie on top of the official Ubuntu 20.04 LTS image.
      Just follow the instructions on the github page, and start the cmd.sh. Its implicit that you have to
      • Set the local ROMs dir
      • Set the local BIOS dir
      • Set the local retroarch autoconfiguration,ES config for user pi and ES config global dirs
      • Have docker configured and installed on your host as well as xhost.
        BuZz administrators @nwildner
        @nwildner maybe this https://retropie.org.uk/forum/topic/32874/
        • N
          nwildner @BuZz
          @BuZz Thanks for the insights.
          So far, no naming mismatch on both configuration files:
          ES:
          es_input.cfg - head
          </inputAction>
            <inputConfig type="joystick" deviceName="Xbox 360 Controller" deviceGUID="030000005e0400008e02000014010000">
          Retroarch autoconfiguration:
          Xbox 360 Controller.cfg       (filename)
          input_device = "Xbox 360 Controller"
          input_driver = "udev"
          Since this is a 8BitDo controller running on cable (Xbox 360 mode) I found the following attributes for udev:
          ATTR{idProduct}=="028e"
          ATTR{idVendor}=="045e"
          Converted to decimal and added them to the .cfg file for retroarch
          head -4 retroarch_autoconfig/Xbox\ 360\ Controller.cfg
          input_vendor_id = "1118"
          input_product_id = "654"
          Didn't worked, unfortunately. Runcommand logs also don't provide a clue of what could be the problem.
          pi@6eaf134e36b6:/dev/shm$ cat runcommand.log
          Parameters:
          Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x/snes9x_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg "/home/pi/RetroPie/roms/snes/Super Mario World (USA).zip" --appendconfig /dev/shm/retroarch.cfg
          Map_LoROMMap
          Any additional ideas?
            @nwildner if you launch with verbose logging via runcommand menu it will provide a lot more information.
            • N
              nwildner @BuZz
              @BuZz
              Meanwhile, me and a friend kept investigating and, root cause found:
              openat(AT_FDCWD, "/run/udev/data/c13:84", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
              openat(AT_FDCWD, "/run/udev/data/+input:input2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
              It seems that retroarch specifically reads these paths while EmulationStation does not require access to those to work.
              Also, tried to revert to Ubuntu 22.04 LTS as base image to build mine because downgrading to 20.04 LTS was a vector of analysis, and the message of "unavailable vendor_id/product_id" on Retroarch notifications started so, the full solution was:
              • Map /run/udev/to the container
              • Keep the image on Ubuntu 20.04 LTS for better compatibility with SDL2 issues.
              I'll update the first post here because, while this is solved, it's a project that I will maintain here, and eventually try to fix any bugs that may come along with it.
              ethelingE 1 Reply Last reply Reply Quote 1
              • ethelingE
                etheling @nwildner
                Below my Docker experiments from a while back in case there might be anything useful there. Caveat emptor, it's been a while, and I haven't used these - at all; they worked ok, sort of, back in the day though.
                URL: https://github.com/etheling/rpie-docker
                  redscorpse
                  I had the same idea, I am trying to run RetroPie on my Raspberry Pi with Debian 11 (I can't install RetroPie on Bullseye) on a Docker container, and I am using my iPad as a screen through Remote Desktop, and a Bluetooth controller (8Bitdo Zero 2), and I can use Emulationstation (my gamepad works fine there) but when I launch any game my controller doesn't work (I don't have a wired controller so I don't know if that's the problem). I've tried to change the retroarch controller configuration and changing it to "sdl2" only works one button... I don't know why. If you don't have any issues maybe I could try your Dockerfile because it might be my setup?
