    Audio devices not found GPi case
    soundgpi casezero w
    11 Posts 4 Posters 1.8k Views
      Souciot
      Hello, I've been going through this site and others for days trying to figure out how to make my audio work on my GPi case...
      I modifyied the config.txt and cmdline.txt with solutions that worked for others but it won't work with me. When I want to change audio in the settings it tells me that no audio device was found. also when i type aplay - l it tells me "no soundcard found"
      I don't know what to do...
      Pi Model or other hardware: Zero W
      Power Supply used: cable 5V or battery
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): v4.8 technically
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used) raspberry pi imager then reinstalled on the raspi-setup
      USB Devices connected: /
      Controller used: GPi case
      Error messages received: "no soundcard found"
      Verbose log (if relevant):
      Guide used: (Mention if you followed a guide) forums
      Attachment of config files: (PLEASE USE PASTEBIN.COM FOR LARGE LOGS) added at the end of confi.txt : https://pastebin.ubuntu.com/p/XT5Yqdwh87/
        Can you post your entire config.txt ?
        I don't think you need any cmdline.txt changes, so you can restore the default one that comes with the image.
          Souciot @mitu
          @mitu Thank you for answering
          I tried reinstalling it with the lastest version available on retropie's web site to see if a clean fresh install would change anything (it didn't). Here's the config.txt that I modified a bit (added 1 line or 2 at the bottom) : https://pastebin.com/ikfRTr67
          for cmdline.txt I just added "snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_compat_alsa=1", so I should remove it ?
            mitu Global Moderator @Souciot
            @Souciot said in Audio devices not found GPi case:
            Are you sure you've not installed Recalbox on it ? The config file you posted is not included with RetroPie and has a lot other configurations for pins 18/19 which may override your own configuration.
            Those shouldn't be neeed, you can remove it.
              Souciot @mitu
              No it is the latest version of retropie for rpi0 I could find, not recalbox
              AshpoolA G 2 Replies Last reply Reply Quote 0
              • AshpoolA
                Ashpool @Souciot
                @Souciot quoting your pasted config.txt
                # default CEC name
                cec_osd_name=recalbox
                  G30FF @Souciot
                  @Souciot Check to make sure that the patch you've applied is for RetroPie and not for Recalbox. RetroFlag provides separate config.txt files for each.
                    Souciot @Ashpool
                    @Ashpool I don't understand : I used raspberry Pi Imager and flashed retropie (first the image it was offering for retropie and then the image downloaded on retropie.org), and before I just erase any partition or volume on my sdcard so I don't understand where this is coming from...
                    AshpoolA 1 Reply Last reply Reply Quote 0
                      Souciot @G30FF
                      @G30FF in the readme of the patch it's written : "Why need to install display GPi Case patch for Retropie and Recalbox?" so I suppose it shouldn't mess with retropie ?
                      • AshpoolA
                        Ashpool @Souciot
                        Ok, sorry my fault, was buffled by that line, but as it seem that is part of the config.txt from the retroflag patch, and from a brief look into it, the only real difference between your posted config.txt and theirs are the additional (last) two lines (#gpi added, dtoverlay=audremap,pins_18_19,enable_jack=on) within yours.
                        @G30FF If I haven't missed it, for the GPICase (not the 2, nor the 2W) there is only one patch provided (one config.txt and two overlays (screen and audio)).
                          G30FF @Souciot
                          I only have experience with the GPi Case 2, so my mistake. The GPi Case 2 patch includes one for Recalbox 7, one for Recalbox 8, one for Batocera, and one for RetroPie. I downloaded the GPi Case 1 patch, and I see why the recalbox string is there, because it's included in the patched config.txt. Sorry, I won't be much help here.
