    Controller not recognized on my raspberry and PC
    controller usbdrivers0x2bcorrupt
    5 Posts 2 Posters 624 Views
      Gecko97
      Hello everyone, here's my problem,
      I brought a n64 controller usb to my retropie and configured it on retropie,
      After some reset of the raspberry, it dosen't work...
      I test it on my pc (windows 10) and there's some errors " usb device not reconized"
      To the Event Viewer, the problem come to the driver "usb.inf" and the error number is "0x2B"
      Did i just break up my controller ???
        Maybe the device needs a driver installed ? Which controller (model/vendor) do you have ?
          Gecko97 @mitu
          i purchase it on aliexpress "https://a.aliexpress.com/_mrwZgZo"
          i'll take 2 on them, the seconde one work very well,
          The controllers just need to be connect on usb port.
            If the 2nd one works, but the 1st not, then it's probably broken/malfunctioning.
              Gecko97 @mitu
              @mitu yeah i think, because i configured it normally, but dosen't work after some reset,
