    Set overlays per system
    retroarchconfig.txtoverlaysglobalretroarch.cfg h
    5 Posts 2 Posters 1.2k Views
    • X
      xxghostbusterxx
      Raspberry PI B+
      Retropie 4.8
      Official PI USB keyboard
      Official PS3 dual shock controller (wired)
      Official pi power supply
      Hi everyone,
      Currently trying to set overlays per system on retropie. I have seen many explanations online, but nothing seems to point to a solution.
      One particular video showed setting an overlay within the retroarch configuration screen when you hotkey +Y when a game is loaded. This seems outdated and overlays do not set with global config saving.
      So...
      My overlays are stored at: opt/retropie/emulators/retroarch/overlays
      I belive the Atari 2600 config file is located at: opt/retropie/configs/atari2600/retroarch.cfg
      Here are the details in the config file:
      video_smooth = "false"
      video_fullscreen_x = "800"
      video_fullscreen_y = "600"
      video_shader_enable = "true"
      video_shader = "/opt/retropie/emulators/retroarch/shader/zfast_crt_curve.glslp"
      aspect_ratio_index = "0"
      input_overlay = "/opt/retropie/emulators/retroarch/overlays/Atari-2600.cfg"
      input_overlay_enable = "true"
      The overlay is listed there but will not load up when a game is started.
      Maybe there is a conflict somewhere.
      Appreciate any help provided.
        sleve_mcdichael @xxghostbusterxx
        @xxghostbusterxx what is the content of the overlay config file /opt/retropie/emulators/retroarch/overlays/Atari-2600.cfg?
        X 1 Reply Last reply Reply Quote 0
        • X
          xxghostbusterxx @sleve_mcdichael
          @sleve_mcdichael the file shows the following detail:
          overlays = 1
           overlay0_full_screen = true
          overlay0_descs - 0
          The corresponding png file is in the same directory.
            @xxghostbusterxx said in Set overlays per system:
            overlay0_descs - 0
            Is that just a transcription error or does it really say - and not =?
            • X
              @sleve_mcdichael yes, that was an error on my part - I am accessing the SD card on another computer with Linux Reader and have to manually copy it across.
              But I discovered something new: if I play a game, hotkey + Y, and set the overlay there, I can save the game config in the overrides section. This only works when assigning an overlay to a single game at a time, not a system via global override.
