    Gamepads Not Recognized after updating Retropie
    gamepad issuegamepad driverretropie update
    17 Posts 3 Posters 3.4k Views
      jdriscol
      Hi,
      I just updated my Retropie (Rasp Pi 3B) after a year or so of not doing so, and I had two generic USB gamepads that worked this whole time. After the update on 1/30/23 (to the current version, though I'm not sure what previous version was running), neither gamepad works anymore on the Retropie. I get the Gamepads Not Recognized message at the start of Emulation Station, but I have indicator lights still working on the gamepads. Weirder yet, when I get past this point using a connected keyboard and then open my Steam Link port, the USB gamepads magically start working. Any ideas??
      I've tried downgrading the driver for the gamepad described here, but it didn't seem to work. I'm not 100% sure I performed all the necessary steps. I edited the driver file pointing to the older version of the driver, but I'm not sure if I need to then manually execute that file or whatever. Any help would be much appreciated!
        Have you tried re-configuring the gamepad(s) in EmulationStation ? The issue you mentioned in another topic has been fixed a long time ago and the downgrade shouldn't be necessary.
        Please post the result of the following commands:
        lsusb
        cat /proc/bus/input/devices
        udevadm info -q all /dev/input/event*
          jdriscol @mitu
          I have the following output for the commands below:
          lsusb
          Bus 001 Device 007: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
          Bus 001 Device 004: ID 04ca:0027 Lite-On Technology Corp.
          Bus 001 Device 005: ID 045e:028e Microsoft Corp. Xbox360 Controller
          Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
          Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
          Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
          Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
          I: Bus=0003 Vendor=04ca Product=0027 Version=0110
          N: Name="Lite-On Technology Corp. USB Multimedia Keyboard"
          P: Phys=usb-3f980000.usb-1.2/input0
          S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:04CA:0027.0001/input/input0
          U: Uniq=
          H: Handlers=sysrq kbd leds event0
          B: PROP=0
          B: EV=120013
          B: KEY=10000 7 ff9f207a c14057ff febeffdf ffefffff ffffffff fffffffe
          B: MSC=10
          B: LED=7
          N: Name="Lite-On Technology Corp. USB Multimedia Keyboard System Control"
          P: Phys=usb-3f980000.usb-1.2/input1
          S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input1
          U: Uniq=
          H: Handlers=kbd event1
          B: PROP=0
          B: EV=13
          B: KEY=400000 0 0 0 0 0 0 0 4000 10cc00 100000 0 0 0
          B: MSC=10
          N: Name="Lite-On Technology Corp. USB Multimedia Keyboard Consumer Control"
          S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input2
          U: Uniq=
          H: Handlers=kbd event2
          B: PROP=0
          B: EV=13
          B: KEY=2000000 3878 d8011001 e0000 0 0 0
          B: MSC=10
          S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input3
          U: Uniq=
          H: Handlers=event3
          B: PROP=0
          B: EV=13
          B: KEY=27 10000800 c8800000 0 0 0 0 0 0 0 0
          B: MSC=10
          I: Bus=0003 Vendor=045e Product=028e Version=0110
          N: Name="Microsoft X-Box 360 pad"
          P: Phys=usb-3f980000.usb-1.1.3/input0
          S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/input/input4
          U: Uniq=
          H: Handlers=event4 js0
          B: PROP=0
          B: EV=20000b
          B: KEY=7fdb0000 0 0 0 0 0 0 0 0 0
          B: ABS=3001b
          B: FF=1 7030000 0 0
          I: Bus=0003 Vendor=046d Product=c077 Version=0111
          N: Name="Logitech USB Optical Mouse"
          P: Phys=usb-3f980000.usb-1.3/input0
          S: Sysfs=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C077.0003/input/input5
          U: Uniq=
          H: Handlers=mouse0 event5
          B: PROP=0
          B: EV=17
          B: KEY=70000 0 0 0 0 0 0 0 0
          B: REL=903
          B: MSC=10
          P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:04CA:0027.0001/input/input0/event0
          N: input/event0
          L: 0
          S: input/by-path/platform-3f980000.usb-usb-0:1.2:1.0-event-kbd
          S: input/by-id/usb-Lite-On_Technology_Corp._USB_Multimedia_Keyboard-event-kbd
          E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:04CA:0027.0001/input/input0/event0
          E: DEVNAME=/dev/input/event0
          E: MAJOR=13
          E: MINOR=64
          E: SUBSYSTEM=input
          E: USEC_INITIALIZED=10713749
          E: ID_INPUT=1
          E: ID_INPUT_KEY=1
          E: ID_INPUT_KEYBOARD=1
          E: ID_VENDOR=Lite-On_Technology_Corp.
          E: ID_VENDOR_ENC=Lite-On\x20Technology\x20Corp.
          E: ID_VENDOR_ID=04ca
          E: ID_MODEL=USB_Multimedia_Keyboard
          E: ID_MODEL_ENC=USB\x20Multimedia\x20Keyboard
          E: ID_MODEL_ID=0027
          E: ID_REVISION=0118
          E: ID_SERIAL=Lite-On_Technology_Corp._USB_Multimedia_Keyboard
          E: ID_TYPE=hid
          E: ID_BUS=usb
          E: ID_USB_INTERFACES=:030101:030000:
          E: ID_USB_INTERFACE_NUM=00
          E: ID_USB_DRIVER=usbhid
          E: ID_PATH=platform-3f980000.usb-usb-0:1.2:1.0
          E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_2_1_0
          E: XKBMODEL=pc105
          E: XKBLAYOUT=us
          E: XKBOPTIONS=lv3:ralt_switch
          E: BACKSPACE=guess
          E: LIBINPUT_DEVICE_GROUP=3/4ca/27:usb-3f980000.usb-1
          E: DEVLINKS=/dev/input/by-path/platform-3f980000.usb-usb-0:1.2:1.0-event-kbd /dev/input/by-id/usb-Lite-On_Technology_Corp._USB_Multimedia_Keyboard-event-kbd
          E: TAGS=:power-switch:
          P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input1/event1
          N: input/event1
          L: 0
          S: input/by-id/usb-Lite-On_Technology_Corp._USB_Multimedia_Keyboard-event-if01
          S: input/by-path/platform-3f980000.usb-usb-0:1.2:1.1-event
          E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input1/event1
          E: DEVNAME=/dev/input/event1
          E: MAJOR=13
          E: MINOR=65
          E: SUBSYSTEM=input
          E: USEC_INITIALIZED=10732831
          E: ID_INPUT=1
          E: ID_INPUT_KEY=1
          E: ID_MODEL_ID=0027
          E: ID_REVISION=0118
          E: ID_TYPE=hid
          E: ID_BUS=usb
          E: ID_USB_INTERFACE_NUM=01
          E: ID_PATH=platform-3f980000.usb-usb-0:1.2:1.1
          E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_2_1_1
          E: XKBMODEL=pc105
          E: XKBLAYOUT=us
          E: BACKSPACE=guess
          E: DEVLINKS=/dev/input/by-id/usb-Lite-On_Technology_Corp._USB_Multimedia_Keyboard-event-if01 /dev/input/by-path/platform-3f980000.usb-usb-0:1.2:1.1-event
          P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input2/event2
          N: input/event2
          L: 0
          E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input2/event2
          E: DEVNAME=/dev/input/event2
          E: MAJOR=13
          E: MINOR=66
          E: SUBSYSTEM=input
          E: USEC_INITIALIZED=10727886
          E: ID_INPUT=1
          E: ID_INPUT_KEY=1
          E: ID_MODEL_ID=0027
          E: ID_REVISION=0118
          E: ID_TYPE=hid
          E: ID_BUS=usb
          E: XKBMODEL=pc105
          E: XKBLAYOUT=us
          E: BACKSPACE=guess
          P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input3/event3
          N: input/event3
          L: 0
          S: input/by-path/platform-3f980000.usb-usb-0:1.2:1.1-event-mouse
          S: input/by-id/usb-Lite-On_Technology_Corp._USB_Multimedia_Keyboard-if01-event-mouse
          E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04CA:0027.0002/input/input3/event3
          E: DEVNAME=/dev/input/event3
          E: MAJOR=13
          E: MINOR=67
          E: SUBSYSTEM=input
          E: USEC_INITIALIZED=10707572
          E: ID_INPUT=1
          E: ID_INPUT_MOUSE=1
          E: ID_MODEL_ID=0027
          E: ID_REVISION=0118
          E: ID_TYPE=hid
          E: ID_BUS=usb
          E: DEVLINKS=/dev/input/by-path/platform-3f980000.usb-usb-0:1.2:1.1-event-mouse /dev/input/by-id/usb-Lite-On_Technology_Corp._USB_Multimedia_Keyboard-if01-event-mouse
          P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/input/input4/event4
          N: input/event4
          L: 0
          S: input/by-id/usb-ShanWan_ZD_Game_For_Windows-event-joystick
          S: input/by-path/platform-3f980000.usb-usb-0:1.1.3:1.0-event-joystick
          E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/input/input4/event4
          E: DEVNAME=/dev/input/event4
          E: MAJOR=13
          E: MINOR=68
          E: SUBSYSTEM=input
          E: USEC_INITIALIZED=10909443
          E: ID_INPUT=1
          E: ID_INPUT_JOYSTICK=1
          E: ID_VENDOR=ShanWan
          E: ID_VENDOR_ENC=ShanWan
          E: ID_VENDOR_ID=045e
          E: ID_MODEL=ZD_Game_For_Windows
          E: ID_MODEL_ENC=ZD\x20Game\x20For\x20Windows
          E: ID_MODEL_ID=028e
          E: ID_REVISION=0110
          E: ID_SERIAL=ShanWan_ZD_Game_For_Windows
          E: ID_TYPE=generic
          E: ID_BUS=usb
          E: ID_USB_INTERFACES=:ff5d01:
          E: ID_USB_DRIVER=xpad
          E: ID_PATH=platform-3f980000.usb-usb-0:1.1.3:1.0
          E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_1_3_1_0
          E: ID_INPUT_JOYSTICK_INTEGRATION=internal
          E: ID_FOR_SEAT=input-platform-3f980000_usb-usb-0_1_1_3_1_0
          E: LIBINPUT_DEVICE_GROUP=3/45e/28e:usb-3f980000.usb-1.1
          E: DEVLINKS=/dev/input/by-id/usb-ShanWan_ZD_Game_For_Windows-event-joystick /dev/input/by-path/platform-3f980000.usb-usb-0:1.1.3:1.0-event-joystick
          E: TAGS=:seat:uaccess:
          P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C077.0003/input/input5/event5
          N: input/event5
          L: 0
          S: input/by-path/platform-3f980000.usb-usb-0:1.3:1.0-event-mouse
          S: input/by-id/usb-Logitech_USB_Optical_Mouse-event-mouse
          E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C077.0003/input/input5/event5
          E: DEVNAME=/dev/input/event5
          E: MAJOR=13
          E: MINOR=69
          E: SUBSYSTEM=input
          E: USEC_INITIALIZED=389636315
          E: ID_INPUT=1
          E: ID_INPUT_MOUSE=1
          E: ID_VENDOR=Logitech
          E: ID_VENDOR_ENC=Logitech
          E: ID_VENDOR_ID=046d
          E: ID_MODEL=USB_Optical_Mouse
          E: ID_MODEL_ENC=USB\x20Optical\x20Mouse
          E: ID_MODEL_ID=c077
          E: ID_REVISION=7200
          E: ID_SERIAL=Logitech_USB_Optical_Mouse
          E: ID_TYPE=hid
          E: ID_BUS=usb
          E: ID_USB_INTERFACES=:030102:
          E: ID_PATH=platform-3f980000.usb-usb-0:1.3:1.0
          E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_3_1_0
          E: LIBINPUT_DEVICE_GROUP=3/46d/c077:usb-3f980000.usb-1
          E: DEVLINKS=/dev/input/by-path/platform-3f980000.usb-usb-0:1.3:1.0-event-mouse /dev/input/by-id/usb-Logitech_USB_Optical_Mouse-event-mouse
          To be clear, I have two identical gamepads, but only one of them were plugged in, the one that's got the Vendor ID ShanWan.
            mitu Global Moderator @jdriscol
            Seems similar to https://github.com/paroj/xpad/issues/119. The clone mimics a Xbox360 controller, but expects some initialization sequence when the connection begins, which is not sent by the driver. Steamlink may send that sequence when starting, that's why the controller starts working when using it.
            What you may try:
            • uninstall the xpad driver completely.
            • make sure RetroPie-Setup script is updated also - if you've run just a package update, that may not have happened.
            • reboot
            • install the xpad driver again. See if the issue persist.
            If the issue still exists, then try the workaround from
            https://gist.github.com/dnmodder/de2df973323b7c6acf45f40dc66e8db3 by running a python script to force initialization. See if that fixes the initialization issue.
              jdriscol @mitu
              Thank you for the advice. I attempted to remove the xpad driver as you described and reinstall it after a reboot. It didn't seem to do anything. The gamepad is still not being picked up by ES. To be clear, I uninstalled/reinstalled the driver through the RetroPie Setup menu. Is that what you mean by uninstalling the driver completely?
              Before I give the Python script a shot, do I need to run that from a particular folder or anything?
              Thanks for the help.
                @jdriscol said in Gamepads Not Recognized after updating Retropie:
                Yes.
                No, any folder would be fine. Just save it to a $HOME/scripts folder and run it from the command line to test it first. If it works, modify /opt/retropie/configs/all/autostart.sh and add a line calling the script, just before the line that starts with emulationstation.
                  jdriscol @mitu
                  Ok, so after spinning my wheels a bit trying to get that python script to run (I'm a bit out of my depth, but trying to learn), it seemed like I got it to execute with no errors. At this point, should the gamepads be working, or not until I add it to the autostart.sh script? I haven't added the line to autostart.sh yet, but I'm still not getting any response from the gamepads.
                  Also, when I call the python script from this shell file, I assume it will be:
                  sudo python3 /home/pi/Scripts/fixcontroller.py
                  Do I have that right?
                    Also, when I call the python script from this shell file, I assume it will be: [..]
                    Yes, that's correct.
                    Just running the script should have enabled the controllers (even without adding it to autorun.sh). If that hasn't solved the controller initialization issue, then your problem is a different one.
                    I wonder what SteamLink does that xpad doesn't.
                      jdriscol @mitu
                      I ended up putting a new image on the Pi and still no luck, initially. Eventually, I changed the mode on the gamepad (which I thought I had tried previously), and now it seems to work. In short, RetroPie only seems to recognize my gamepad in DirectInput mode instead of XInput since some update (unknown) of RetroPie. (Previously my gamepad worked in XInput mode no problem.) This is pretty annoying because it means I lose the rumble functionality in my games, plus it swaps out the left d-pad with the left stick.
                      Any ideas on how to resolve this specific issue?
                        Assuming it's an xpad change that triggers this problem, you can try and install an older version. Do you known which version of RetroPie you had installed before the update - that would help narrow down the xpad version which didn't have the problem.
                          jdriscol @mitu
                          I'm pretty sure my previous build was 4.7.1. I just went back and reviewed the thread in my initial post and realized that after updating the xpad shell file
                          rp_module_repo="git https://github.com/paroj/xpad.git master 389e258"
                          I never went back to update the driver. I attempted that, but got the following error log:
                          Log started at: Sun  5 Feb 13:02:39 PST 2023
                          RetroPie-Setup version: 4.8.2 (b956140c)
                          System: rpi3 (armv7l) - Raspbian GNU/Linux 10 (buster) - Linux retropie 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                          Update is available - updating ...
                          Installing dependencies for 'xpad' : Updated Xpad Linux Kernel driver
                          /home/pi/RetroPie-Setup/tmp/build/xpad /home/pi
                          Getting sources for 'xpad' : Updated Xpad Linux Kernel driver
                          git clone --recursive --branch master "https://github.com/paroj/xpad.git" "/opt/retropie/supplementary/xpad"
                          Cloning into '/opt/retropie/supplementary/xpad'...
                          Winding back https://github.com/paroj/xpad.git->master to commit: #389e258
                          fatal: '389e258' is not a commit and a branch '389e258' cannot be created from it
                          HEAD is now in branch 'master' at commit '1bdf0926376e9a256d32619122e755923de1dd0a'
                          patching file xpad.c
                          Hunk #1 succeeded at 78 with fuzz 2 (offset -8 lines).
                          Hunk #2 succeeded at 2255 (offset 471 lines).
                          Successfully applied patch: /home/pi/RetroPie-Setup/scriptmodules/supplementary/xpad/01_enable_leds_and_trigmapping.diff
                          patching file dkms.conf
                          Successfully applied patch: /home/pi/RetroPie-Setup/scriptmodules/supplementary/xpad/02_dkms_updates_folder.diff
                          Error running 'git -C /opt/retropie/supplementary/xpad checkout -f 389e258 -b 389e258' - returned 128
                          /home/pi
                          Log ended at: Sun  5 Feb 13:02:41 PST 2023
                          Total running time: 0 hours, 0 mins, 2 secs
                          Am I missing a step here?
                            Revert your changes to the script, cleanup the source folder (from the RetroPie-Setup xpad package's menu) and then you can reinstall.
                              jdriscol @mitu
                              I'm not clear on the next steps. Are you saying to get rid of the "389e258" portion of the xpad shell file and just re-install the driver? I've tried that already and still the same result as I had at the beginning of all this.
                                BuZz administrators @jdriscol
                                @jdriscol did you update the RetroPie-Setup script?
                                  jdriscol @BuZz
                                  @BuZz
                                  I have been running with the latest version of the retropie setup script, v4.8.2. During this time, I tried uninstall and reinstalling the xpad driver. I continue to have the issue where the gamepad is not recognized at all when I have it in Xinput mode (though it had previously worked in this mode for years), and it only works in DirectInput mode. This is problematic because it forces a swapped directional hat/left joystick on the player 2 port when the controllers are in DirectInput mode.
                                  I did attempt at switching controller modes midgame in a ROM just to see what happens, and I got this screenshot. This shows that ES just can't seem to pick up my gamepad anymore in Xinput mode and not sure how to fix that.
                                    This seems like an xpad regression w.r.t. your controller. The driver is installed from the upstream xpad repository, so there's not much we can do in RetroPie to fix it.
                                    Just to confirm that the version shipped with 4.7.1 still works with your gamepad, you can install an older version from that time (Nov 2020).
                                    • make sure you're on the latest RetroPie-Setup release
                                    • uninstall the xpad driver from RetroPie-Setup
                                    • backup the xpad.sh file from $HOME/RetroPie-Setup/scriptmodules/supplementary and modif it as described here, but use the commit before 4.7.1 was released instead:
                                      rp_module_repo="git https://github.com/paroj/xpad.git master dc34631eed83aa9cffaa"
                                    • install again the xpad driver and reboot, then try to see if the gamepad works again.
                                      jdriscol @mitu
                                      Yeah, still no luck. So strange, as I had been able to use my gamepads in Xinput mode for at least a couple years from maybe 2019 onward till I updated my whole RetroPie OS and packages just a couple weeks ago. However, in going through the comments in github for xpad, it does seem like others are having issues with connecting their wired controllers through Xinput mode. Either way, thanks for your help up to this point and I'll keep digging around.
