    [SOLVED] BIOS problem with lr-neocd
    neogeo cdlr-neocdbios not found
    5 Posts 2 Posters 2.2k Views
      Piersi
      I'm trying to emulate NeoGeo CD with lr-neocd, so:
      • I installed lr-neocd from source from the Retropie-Setup Script.
      • I created a folder named neocd in /home/pi/RetroPie/BIOS and put inside it the two BIOS required by lr-neocd (as it is written in Package Help of lr-neocd in the Retropie-Setup Script), which are ng-lo.rom and uni-bioscd.rom. I cheched the SHA1 of uni-bioscd.rom (I don't know what the SHA1 of ng-lo.rom should be), to make sure it matched the one in here https://github.com/libretro/neocd_libretro.
      • I followed the tutorial to create a system in ES for NeoGeo CD explained here https://retropie.org.uk/forum/topic/26064/neo-geo-cd-for-dummies.
      • I put .chd and .CHD games into the /home/pi/RetroPie/roms/neogeocd folder.
      EmulationStation shows the games in the proper system, but when I try to load a game the screen firstly shows the Runcommand Launch Menu, then becomes black and eventually throws me back to ES after about 5 seconds.
      I tried to launch it with verbose logging and it turned out this https://pastebin.com/LbGyc6rx.
      Is this error caused by a BIOS problem or by something else that I did wrong while setting up lr-neocd? How can I solve this problem in order to play NeoGeo CD games?
      Thank you in advance.
      Raspberry Pi 3 Model B Rev 1.2
      EmulationStation 2.11.0RP
      ASUS smartphone battery charger (Input 100-240V 0.3A 50-60Hz; Output 5V = 2A)
      • DarksaviorD
        Darksavior @Piersi
        @troicarp-1 I tested it right now with only the uni-bioscd.rom and it works here.
        It loads without ng-lo.rom. Checking the github, the requirement is gone. It was required at one point, I believe.
        I didn't do anything special to run it. Provide more information to get proper support. The link above will tell you how. Retropie version, emulator version, how was it built, etc.
          Piersi
          @Darksavior said in BIOS problem with lr-neocd:
          Thank you for your answer, but unfortunately in my case it didn't work. What I did to check this was:
          • removeng-lo.rom from /home/pi/RetroPie/BIOS/neocd.
          • use the Update option from the Retropie-Setup Script (just to double-ckeck that everything was up to date).
          • reboot the Pi and launch a NeoGeo CD game.
          However, nothing changed. The verbose logging looks the same as before https://pastebin.com/3cT1578h.
          I don't know if this means something, but I found out that in /opt/retropie/configs/all/retroarch/cores I have neither libneocd_libretro nor neocd_libretro.info , which are files required by https://github.com/libretro/neocd_libretro. I used the Find option to search those files in the entirety of the Pi, but it couldn't find them. I even tried to re-install lr-neocd from source, but unfortunately those two files didn't appear.
          You're right, I'm sorry. I'll provide them now.
          Raspberry Pi Model: 3 Model B Rev 1.2
          Power supply: ASUS smartphone battery charger (Input 100-240V 0.3A 50-60Hz; Output 5V = 2A)
          RetroPie Version: 4.8.3
          Built form: the original Raspberry Pi Imager
          EmulationStation version: 2.11.0RP
          Emulator: lr-neocd commit 2070f5258c9d3feee15962f9db8c8ef20072ece8
          Controller used: Sony PlayStation 4 Dualshock 4, connected either via Bluetooth (without ds4drv) or via cable
          • DarksaviorD
            Darksavior @Piersi
            @troicarp-1 I see your problem. Your log says:
            [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS/neocd/".
            My log says: [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
            You weren't supposed to change the directory. Open Retroarch and change the bios folder back to /home/pi/RetroPie/BIOSbut leave the bios file in /home/pi/RetroPie/BIOS/neocd
              Piersi
              @Darksavior You're right! I changed it back and everything worked as supposed. Thank you very much!
