    After swapping AudioHat no sound
    iqaudioaudio driveraudio issueno sound issuealsa
    3 Posts 1 Posters 406 Views
    • H
      hopwon
      Hi
      I am unable to get my new IQAudioHQ AMP+ card to output any sound on my existing system. I used to have the Innomaker Audio hat which I had configured and was working fine.
      Now with the IQ audio I cannot get any sound output. It should be a simple matter of changing the drive in /boot/config.txt, which I have done but still no sound.
      To test the card I created a stock image of RP OS and followed the instructions to install the card and this works so we know the card is ok.
      However providing the same edits in my existing system no sound.
      I have tested and checked the ALSA config as much as my capabilities allow and everything looks OK.
      Perhaps a symptom is that if, in the RP menu I change the volume to a reasonable value, if the playback device is PCM the volume resets to zero
      dmesg: https://pastebin.com/HcxntMmK
      aplay -L: pi@pacman:~ $ aplay -L
      null
      Discard all samples (playback) or generate zero samples (capture)
      jack
      JACK Audio Connection Kit
      pulse
      PulseAudio Sound Server
      default
      Playback/recording through the PulseAudio sound server
      sysdefault:CARD=IQaudIODAC
      IQaudIODAC, IQaudIO DAC HiFi pcm512x-hifi-0
      Default Audio Device
      dmix:CARD=IQaudIODAC,DEV=0
      Direct sample mixing device
      dsnoop:CARD=IQaudIODAC,DEV=0
      Direct sample snooping device
      hw:CARD=IQaudIODAC,DEV=0
      Direct hardware device without any conversions
      plughw:CARD=IQaudIODAC,DEV=0
      Hardware device with all software conversions
      usbstream:CARD=IQaudIODAC
      IQaudIODAC
      USB Stream Output
      pi@pacman:~ $ cat /etc/asound.conf
      pcm.!default {
      type hw
      card 0
      ctl.!default {
      type hw
      card 0
      alsa.conf: https://pastebin.com/HPaXdXCj
      aplay output: https://pastebin.com/1Hib9686
      /boot/config.txt https://pastebin.com/KNYn9cxU
      I've spent hours trying to research and fix this but I am out of ideas so would appreciate some help from an expert :)
      Bottom line is swapping the innomaker HAT for the IQAudio HAT = no sound.
      Put the IQAudio HAT on a default PI build and it works fine.
      If I put the Innomaker HAT back on my original PI and change the driver back it works fine.
      Is there a way to uninstall the complete sound system and reinstall as this would be my next step.
      Thanks and regards
      • H
        hopwon @hopwon
        @hopwon Update:
        Removed pulse-audio with apt-get, and then I get an error message during speaker-test:
        pi@pacman:~ $ speaker-test -t2 -c2 -twav -Dhw
        speaker-test 1.1.8
        Playback device is hw
        Stream parameters are 48000Hz, S16_LE, 2 channels
        WAV file(s)
        Playback open error: -16,Device or resource busy
        So I shutdown (exited) RP gui and lo and behold speaker test now works!:
        pi@pacman:~ $ speaker-test -t2 -c2 -twav -Dsysdefault
        speaker-test 1.1.8
        WAV file(s)
        Rate set to 48000Hz (requested 48000Hz)
        Buffer size range from 128 to 131072
        Period size range from 64 to 65536
        Using max buffer size 131072
        Periods = 4
        was set period_size = 32768
        was set buffer_size = 131072
         0 - Front Left
         1 - Front Right
        Time per period = 0.715188
         0 - Front Left
         1 - Front Right
        So I started RP back up again and no sound but I get the "startup sound" from the IMP music player I have for the menu which got me thinking somehow the IMP program is blocking the sound card. So I "stopped" IMP and now its working as designed. I think I will uninstall/reinstall IMP with the new Sound Card
        • H
          hopwon @hopwon
          That did the trick, uninstall IMP using the install script to do the uninstall.
          Check all the sound was working as expected and it was
          Reinstall of imp and I have audio goodness coming out of my Arcade Machine again :)
