    Help installing emulator ir-snes9x
    emulatorhelp me please
    7 Posts 4 Posters 958 Views
      DukeHash
      Hello dear community, I can't install the ir-snes9x emulator, the log is attached. Please help, thank you very much for your attention.
      Log started at: Sun 16 Apr 18:33:58 BST 2023
      RetroPie-Setup version: 4.6.7 (b6bb01b2)
      System: rpi3 (armv7l) - Raspbian GNU/Linux 10 (buster) - Linux retropie 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
      /home/pi/RetroPie-Setup/tmp/build/lr-snes9x /home/pi/RetroPie-Setup
      Getting sources for 'lr-snes9x' : Super Nintendo emu - Snes9x (current) port for libretro
      git clone --recursive --depth 1 --branch master "https://github.com/libretro/snes9x.git" "/home/pi/RetroPie-Setup/tmp/build/lr-snes9x"
      Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-snes9x'...
      Submodule 'shaders/SPIRV-Cross' (https://github.com/KhronosGroup/SPIRV-Cross.git) registered for path 'external/SPIRV-Cross'
      Submodule 'shaders/glslang' (https://github.com/KhronosGroup/glslang.git) registered for path 'external/glslang'
      Submodule 'external/vulkan-headers' (https://github.com/KhronosGroup/Vulkan-Headers.git) registered for path 'external/vulkan-headers'
      Submodule 'win32/libpng/src' (https://git.code.sf.net/p/libpng/code) registered for path 'win32/libpng/src'
      Submodule 'win32/zlib/src' (https://github.com/madler/zlib.git) registered for path 'win32/zlib/src'
      Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-snes9x/external/SPIRV-Cross'...
      Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-snes9x/win32/libpng/src'...
      fatal: unable to access 'https://git.code.sf.net/p/libpng/code/': server certificate verification failed. CAfile: none CRLfile: none
      fatal: clone of 'https://git.code.sf.net/p/libpng/code' into submodule path '/home/pi/RetroPie-Setup/tmp/build/lr-snes9x/win32/libpng/src' failed
      Failed to clone 'win32/libpng/src'. Retry scheduled
      Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-snes9x/win32/zlib/src'...
      Failed to clone 'win32/libpng/src' a second time, aborting
      Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-snes9x/external/glslang'...
      Cloning into '/home/pi/RetroPie-Setup/tmp/build/lr-snes9x/external/vulkan-headers'...
      HEAD is now in branch 'master' at commit 'b931ad0cb4fe209a659ce6f47b3c2986059792fa'
      Error running 'git clone --recursive --depth 1 --branch master https://github.com/libretro/snes9x.git /home/pi/RetroPie-Setup/tmp/build/lr-snes9x' - returned 1
      Log ended at: Sun 16 Apr 18:35:26 BST 2023
      Total running time: 0 hours, 1 mins, 28 secs
      • windgW
        windg
        Your RetroPie Setup script version is old. I suggest to update the system and then try again. Instructions: https://retropie.org.uk/docs/Updating-RetroPie/
          DukeHash @windg
          @windg said in Help installing emulator ir-snes9x:
          Thanks for the hint. Can I install the ir-snes9x binary separately? how can I do not to update the whole retropie?
          mituM windgW 2 Replies Last reply Reply Quote 0
            sleve_mcdichael
            @DukeHash said in Help installing emulator ir-snes9x:
            You could try clone the latest RetroPie-Setup manually into a temp directory and install just the lr-snes9x core from there.
            https://github.com/RetroPie/RetroPie-Setup
            https://retropie.org.uk/docs/Manual-Installation/#install-retropie
              mitu Global Moderator @DukeHash
              Why do you want to install it separately ? You can install the binary package instead of installing from source - it should get you almost the same version.
              • windgW
                windg @DukeHash
                @DukeHash Without be sure if this will work , try to update only the retropie setup script and then install the emulator.
                  DukeHash @windg
                  Thank you all very much for your help. Everything turned out updating the script retropie_setup.sh . Thanks a lot
