    RetroArch UI - Gamepad issue
    retroarchui issuegamepad
    16 Posts 3 Posters 1.7k Views
    • DTEAMD
      DTEAM
      Hi @mitu ,
      I uploaded and updated all "core packages" in "Retropie setup"
      Now when I go to the Retroarch UI everything works fine except for the up and down buttons. I can jump up and down with a big jump with L2 and R2 and jump to the end with L3 , but the cross and/or the analog stick doesn't work. Where can I set the keys (the file) only for the UI. For games, it works well.
      New editing: Strangely, it took me 20 sec in the UI before I could use some buttons. The cross and the joystick never work.
      I dont see my controller in /home/pi/RetroPie-Setup/tmp/build/retroarch/autoconfigs/sdl2 and /home/pi/RetroPie-Setup/tmp/build/retroarch/autoconfigs/udev . Is it normal?
      Thanks, best regards
        @DTEAM said in RetroArch UI - Gamepad issue:
        Hi @mitu ,
        Can you please provide the info I asked in the previous topic ?
        • DTEAMD
          DTEAM @mitu
          My runcommand.log
          Parameters:
          Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-genesis-plus-gx/genesis_plus_gx_libretro.so --config /opt/retropie/configs/mastersystem/retroarch.cfg "/home/pi/RetroPie/roms/mastersystem/Shinobi (USA, Europe).zip" --appendconfig /dev/shm/retroarch.cfg
          Is It the good log file?
            mitu Global Moderator @DTEAM
            No, enable verbose logging and post the /dev/shm/runcommand.log contents on pastebin.com.
            Also, can you provide some info about your system/gamepad/RetroPie version/etc. ?
            • DTEAMD
              DTEAM @mitu
              It does that with 3 gamepads including one already auto-configured in
              My gamepads:
              DragonRise Inc. Generic USB Joystick (already autoconfigured)
              USB Gamepad (commercial one)
              Teensyduino KeyboardMouseJoystick (homemade with Arduino)
              Here's my pasrebin file: https://pastebin.com/TgwUjZ0D
              Another one with another game: https://pastebin.com/h7JUEfCk
              Thorr69T mituM 2 Replies Last reply Reply Quote 0
              • Thorr69T
                Thorr69 @DTEAM
                @DTEAM You still haven't given the most important info
                Pi Model
                RetroPie version
                Installation source
                RPi 3b
                Official PSU
                Official RetroPie image
                Pandora's Box 5 controller
                • DTEAMD
                  DTEAM @Thorr69
                  @Thorr69
                  Pi4
                  Original image from Retropie website v. 4.8
                  Actual version 4.8.4
                  Core packages updated via binary (last versions)
                    I don't see anything special in the logs. If the gamepad works in-game, the same mapping should work in the RetroArch's menus - I don't think that's changed. Is the Teensyduino controller configured as a gamepad or as a keyboard in RetroArch ? Try re-configure it again in EmulationStation, this will re-generate the configuration profile for RetroArch.
                    The /home/pi/RetroPie-Setup/tmp/build/retroarch/autoconfigs/ has nothing to do with the RetroArch's configuration, the tmp/build folder is used for source installation and it's usually empty - emulators don't load any configuration from it.
                    • DTEAMD
                      DTEAM
                      Hi,
                      I did some tests and the problem seems to be the link between ES controllers configuration and Retroarch .
                      I reinstalled retroarch and I got no error in the installation log (/home/pi/RetroPie-Setup/logs).
                      I deleted es_input.cfg and all my controllers .cfg (such as Teensyduino KeyboardMouseJoystick.cfg). When I set my controllers again, it set es_input.cfg but didn't create .cfg files in :
                      /opt/retropie/configs.hdmi/all/retroarch/autoconfig
                      It's seems to be a communication problem between ES and retroarch. I don't know what to do with that.
                        It's because you deleted the input.cfg file. This is where the path to the auto-configuration script that takes EmulationStation's configurations and writes the configuration profile for RetroArch (and other emulators) is kept. I said to just re-configure the gamepad, not to delete any file(s).
                        I advise you to re-install EmulationStation and check if the input.cfg is created, then configure your joystick again in EmulationStation.
                        • DTEAMD
                          DTEAM @mitu
                          @mitu said in RetroArch UI - Gamepad issue:
                          Thank you, I solved this problem with your recommendation. Unfortunately, the Retroarch UI problem remains.
                          Is there a file somewhere in the opt folder that can cause this problem? A file that takes precedence over . cfg files in /opt/retropie/configs/all/retroarch/autoconfig for UI only?
                            Post your retroarch.cfg on pastebin.com, the one from /opt/retropie/configs/all. Also, post your controller .cfg file.
                            • DTEAMD
                              DTEAM
                              See hyperlinks below:
                              retrorch.cfg
                              /opt/retropie/configs/all :
                              USB Gamepad .cfg
                              /opt/retropie/configs/all/emulationstation :
                              es_input.cfg
                              • DTEAMD
                                DTEAM @DTEAM
                                retroarch.cfg.rp-dist
                                Another point, I must press "select" first in UI to activate it. It wasn't the case before. Only the arrows doesn't work. It dosn't work with the keyboard also but F1, enter, esc, etc work. It's an "up" and "down" buttons problem
                                  The entire retroarch.cfg has more than 3000 lines, so there's no way to discern what's the option that may be causing this. I don't know what version of RetroArch you were using before, but the current version (1.15) has received a number of input related changes recently (after 1.12) and your issue may be triggered by those changes and some options you have saved in your .cfg.
                                  My advice would be to back-up your current retroarch.cfg and use the RetroPie default one (retroarch.cfg.rp-dist).
                                  I'm not sure that this means - you need to press Select to open the menu or to change an option in the menu ? If it's opening the menu, then it's normal - the opening is a combination of the hotkey_enable (which is mapped to Select) and the menu_toggle hotkey (which is mapped to X).
                                  What was the behavior before ?
                                  DTEAMD 1 Reply Last reply Reply Quote 2
                                  • DTEAMD
                                    DTEAM @mitu
                                    It works now. Thanks
                                    The problem seems to be from the new retroarch.cfg file . With no retroarch.cfg file, it works well. When I reinstall retroarch, the new retroarch.cfg file create that problem. I don't know why? Probably, a new setting create that
                                    NEW EDIT:
                                    In the new retroarch.cfg I changed all_users_control_menu = "true" for "false"
                                    and now everything is fine. That was the problem.! Don't know if other people got this issue, but on on my side, this solved the problem.
                                    Thanks a lot for the support !
