    RetroPie x86 Help (terminal & display)
    terminal
    2 Posts 2 Posters 347 Views
      slevecore
      So I have installed and reinstalled Ubuntu and RetroPie, but when emulation station starts up, the terminal can be seen at the top edge of the screen. The bottom edge of emulation station is cut off as well. I can't locate any settings to adjust this. Any ideas? Anyone come across this?
        Try using the Gnome on Xorg session to log in, instead of the default (Gnome on Wayland). The issue occurs because of the Wayland session and SDL's fullscreen mode, which doesn't cover the entire screen.
