    Problem with accessing retropie by WinSCP but not with explorer "\\retropie"
    retropiewinscpputty\\retropie
    2 Posts 2 Posters 394 Views
      Gabbo999
      Hi everyone,
      after a long time i want to add some games in my retropie.
      The problem is that i can access to it with explorer from windows searching "\ip address" and after putting username and password, but when i try to use WinSCP or Putty they say Access Denied after i put my password.
      Can someone help me?
      Thank you very much.
      • windgW
        windg
        Do you have the SSH enable from the raspi-config > Interfacing Options menu?
        If it is enable, then, try to restart the router and the pi, maybe this will help.
