    Problem with RetroPie on Raspberry Pie
    raspberry pi 4
    11 Posts 5 Posters 1.2k Views
    • L
      Luirru
      Pi Model or other hardware: Raspberry Pi 4
      Power Supply used: The one it came with
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 2.11.2RP
      Built From: Samba 4.18.2 I think
      USB Devices connected: Yes, 1TB
      Controller used: SNES and PS1
      Error messages received: N/A
      Verbose log (if relevant): N/A
      Guide used: https://retropie.org.uk/docs/Playstation-1/
      Emulator: RetroPie, Playstation
      How to replicate the problem: I am having trouble with my Raspberry Pi 4. I am trying to get my PlayStation bios on there and I transferred it via USB. I put it into the USB following the folders set-up and included ROMs on there. I can verify the files are transferred to the proper place on the file manager. However, I still do not have the option to even see that emulator. I have already downloaded the emulator via update and confirmed it is fully updated. What can I do?
        Did you restart EmulationStation after copying the ROMs ? What are the name of the (ROM/CD image) files that you copied for SNES and Playstation 1 ?
        • L
          Luirru @mitu
          @mitu The SNES is not a problem, I was just using it as a controller. Yes, I have reset both ES and the Pie itself multiple times. Here is a copy of the BIOS names in the file and folder, I hope this helps.
            Did you copy any PS1 games, if so - what are the names of the files ? Without any PS1 games copied, the system will not be displayed.
              sleve_mcdichael @Luirru
              @Luirru said in Problem with RetroPie on Raspberry Pie:
              mitu asked for the name of the rom file, not the BIOS. We are looking for something like:
              Castlevania - Symphony of the Night (USA).chd
              or
              Spyro the Dragon (USA).bin
              Spyro the Dragon (USA).cue
              (You need both the files for BIN/CUE format.)
              These should be in the roms/psx folder, so it should look like:
              /home/pi/RetroPie/roms/psx/Tekken 3 (USA).chd
              ...or
              \\retropie > roms > psx > WipeOut XL (USA).bin (and accompanying .cue)
              • L
                Luirru @sleve_mcdichael
                @sleve_mcdichael OK, thank you for the clarification. I am using the one I update from the Raspberry Pie library, I believe it is PCSX-ReARMed (I used this guide: https://raspberrytips.com/play-psx-games-on-retropie/ when doing it as well).
                Here is the ROM list, they are in the psx folder:
                • sirhenrythe5thS
                  sirhenrythe5th @Luirru
                  @Luirru they are all still packed ;)
                  You have to unpack the files to get usable images (.bin/.cue, *.chd, *.pbp, *.img,...)
                  RetroRatio: 1.91
                  Started Games beaten: 2,40%
                  L 1 Reply Last reply Reply Quote 1
                  • L
                    Luirru @sirhenrythe5th
                    @sirhenrythe5th When I try to unzip I get this message:
                    Is there a different way to unpack them and I just do not know about it?
                      mitu Global Moderator @Luirru
                      @Luirru What program are you using to unpack them ? What archive format are the files - .zip, .rar ?
                      • windgW
                        windg
                        It looks that is using the Windows archiver that is very limited. I recommend the free 7zip.
                        • L
                          Luirru
                          Yup, you guys were right. 7zip did the trick. Thank you SO MUCH, I was going crazy trying to figure it out.
