    ATARIST rom boot problem
    atarist
    2 Posts 1 Posters 171 Views
    • 2
      22marco77
      Pi model or other hardware: pi 3 B+,
      power supply used: universal raspberry power supply
      used RetroPie version 4.8.4 buster
      built from: downloaded image from retropie official site, installation from scratch
      connected USB devices: none
      controller used:
      DragonRise error messages received:
      Detailed log (if applicable):
      Log started at: Wed 24 May 2023, 09.15.45, CEST
      RetroPie-Setup version: 4.8.4 (0bcf01d4)
      System: rpi3 (armv7l) - Raspbian GNU/Linux 10 (buster) - Linux retropie 5.10.103-v7+ #1529 SMP Tue Mar 8
      Parameters:
      Executing: LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/ retropie/configs/atarist/retroarch.cfg "/home/pi/RetroPie/roms/atarist/Simpsons - Bart vs the Space Mutants.zip" --appendconfig /dev/shm/retroarch.cfg
      Hatari v1.8.0, compiled on: May 23 2023, 22:45:12
      IPF : IPF_Init
      IPF : capsimage library version release=5 revision=1
      Configured max Hatari resolution = 832x548, optimal for ST = 832x588
      Inserted disk '/tmp/retroarch/Simpsons, The - Bart vs the Space Mutants (1991)(Ocean)[cr Pompey Pirates][t +2].st' to drive A:.
      NVRAM not found at '/home/pi/.hatari/hatari.nvram'
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 1319: 10375 Segmentation fault LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt /retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/retropie/configs/atarist/retroarch.cfg "/home/pi/RetroPie/roms/atarist/Simpsons - Bart vs the Space Mutants.zip" - -appendconfig /dev/shm/retroarch.cfg
      I have the bios in the appropriate bios folder in retropie
      Emulator: hatari and lr hatari
      • 2
        22marco77
        you can close the discussion, I solved the problem, I don't know why but I had to overwrite the tos file in the bios and everything worked again
