    Flycast Naomi help
    helpflycastseganaomiguilty gear
    4 Posts 2 Posters 848 Views
      cypress
      I am trying to run Naomi games on my raspberry pi 4, and I can not select the zip file to run. It says I'm supposed to run the zip not the folder, but only the folder shows up in the dreamcast directory. What should I do? Thanks everyone who works on this btw, great program
        sleve_mcdichael @cypress
        @cypress you've not put the .zip file inside the folder, have you? It sounds like you maybe have one that needs a .chd file also; that's what will go inside the folder. The .zip just goes in the main dreamcast (or I use arcade) folder:
        arcade/ikaruga.zip
        arcade/ikaruga/
        arcade/ikaruga/gdl-0010.chd
          cypress @sleve_mcdichael
          @sleve_mcdichael No no, the zip is in the dreamcast folder. I put an extra in the arcade folder too, but for some reason Arcade folder does not show up on the list. Maybe my retroarch just isn't updating games list?
          arcade/ikaruga.zip
          arcade/ikaruga/
          Does this mean it requires 3 folders total?
          Thank you for your response btw. I've been trying to figure this out all day and my googling and searching here hasn't helped me
            cypress @cypress
            @cypress I figured it out! My games list just wasn't updating, they now run correctly from the arcade folder. Thanks!!
