    I need help with ParaLLEl N64 for RPI 4
    n64mupen64plusparallel64retroarch 1.8.8
    6 Posts 3 Posters 781 Views
      A Former User
      Hello, I need help using ParaLLEl N64 on Retropie for RPI 4. I'm having trouble finding the GFX Plugins.
      Need Response ASAP for a birthday present
      -Dominic
        The ParaLLEI plugin is not built on the PI4 (or any SBCs for that matter).
          A Former User @mitu
          @mitu is there a diffrent way to improve the n64 graphics then?
          hawkes_84H 1 Reply Last reply Reply Quote 0
          • hawkes_84H
            hawkes_84 @A Former User
            @DominicSD pick one of the high res emulator options like Mupen64plus Glide High res when starting up a game. Works for many of the big titles on n64
            ? 1 Reply Last reply Reply Quote 1
              A Former User @hawkes_84
              @hawkes_84 It choses it automatically. I'm Trying to get good graphics on rush 2
              • hawkes_84H
                @DominicSD when you select the game it gives you a grey box asking you to press A if you wish change any resolution or emulator settings. If you press A then it should bring you to a menu and a list of emulators to choose from. If you're saying you've already tried Gliden and the others then that's the best the Rp4 can do for now for n64
