    Cross-compile packages for RPI1
    cross compilemamerpi zero
    20 Posts 4 Posters 2.0k Views
    • FollyF
      Folly
      Recently I wanted to experimented with running mame standalone on an RPI zero W.
      Just to see if low-end drivers would run with enough speed on a zero.
      I decided to alter the mame.sh module-script so it would only compile channelf on a zero.
      It took about 60 hours to complete but it worked quite good when enabling "-frameskip 10" in the mame command.
      Now I want to test some more drivers but building mame totally would take more than a month i read in this topic :
      https://retropie.org.uk/forum/topic/19303/installation-of-mamedev-mame
      I that topic cross-compiling is also described as a solution.
      Just to speed up the proces of making a binary for the zero quicker.
      So I tried these steps (https://retropie.org.uk/forum/topic/19303/installation-of-mamedev-mame/55) :
      # install dependancies for the cross-compiler environment
      sudo ./retropie_packages.sh crosscomp depends
      # build the cross-compiler
      sudo ./retropie_packages.sh crosscomp setup bullseye
      Also tried buster in above line.
      I tried on many OSes (Ununtu 18.04 / Debian buster / Debian bullseye )
      However the setup will not compete.
      Any Idea if this approach still works or what I am missing here ?
      binary for my RPI zero / zero W.
        It should be possible, but it's a bit more complicated. Haven't used it in a long time, so I forgot how to use the builder to build packages.
        If you have a Pi4, you can compile a Pi0/1 binary by using the __platform=rpi1 option when building:
        sudo ./retropie_packages __platform=rpi1 mame
        and it will create a Pi1/0 compatible package under /opt/retropie/emulators/mame.
        • FollyF
          Folly @mitu
          @mitu said in Cross-compile packages for RPI1:
          That's even simpler ;-)
          I will try that first.
          I tried this but it fails :
          sudo ./retropie_packages.sh __platform=rpi1 mame
          No module '__platform=rpi1' found.
          Is the command correct ?
          Of-course I removed the the !arm6 flag from the mame.sh module script.
            mitu Global Moderator @Folly
            @Folly Hm, I think I switched the order of the arguments:
            sudo __platform=rpi1 ./retropie_packages.sh mame
            • FollyF
              Folly @mitu
              I was thinking somewhat the same.
              I will try.
              Edit :
              Command seems to be correct now.
              When the flag !arm6 is on it will complain so that is a conformation that the __platform string is read correctly.
              Had to change the module-scrip as it produces an error :
              GCC 10.2.1 detected
              makefile:1054: *** Python is not available in path.  Stop.
              strip: 'mame': No such file
              Removing additional swap
              Could not successfully build mame - MAME emulator (/home/pi/RetroPie-Setup/tmp/build/mame/mame not found).
              Errors:
              I changed it into this, so it will not produce the python error and it will only compile for channelf hopefully ( it already runs now ;-) ) :
              function build_mame() {
                  # More memory is required for 64bit platforms
                  if isPlatform "64bit"; then
                      rpSwap on 8192
                  else
                      rpSwap on 4096
                  fi
                  # Compile MAME
                  #local params=(NOWERROR=1 ARCHOPTS=-U_FORTIFY_SOURCE PYTHON_EXECUTABLE=python3)
                  #QT_SELECT=5 make "${params[@]} SUBTARGET=mame SOURCES=fairchild/channelf.cpp"
                  #strip mame
                  make SUBTARGET=mame SOURCES=fairchild/channelf.cpp
                  rpSwap off
                  md_ret_require="$md_build/mame"
              Edit :
              First try failed, probably need to increase the swap space (running on Raspi OS Debian 11 32 bit OS on RPI4/8GB)
                Add manually more swap (8/12Gb ?) before compiling, the memory requirements for compilation fluctuate from release to release with MAME.
                • FollyF
                  Folly @mitu
                  Indeed I will try that later.
                  Looks promising though.
                  • FollyF
                    Folly @mitu
                    Doesn't seem to be the issue, it still fails.
                    Although, I will indeed add more with future tests to prevent this issue.
                    I see something like this in the "log" :
                    PTR64 is on but compiled for 32 bits
                    Not sure if it is related but it could be
                    I will try some simpler packages first to see if that will work.
                    Could also be that it doesn't work correctly on Bullseye 32 bits.
                    Will have a look at what Buster 32 bits does.
                      @Folly said in Cross-compile packages for RPI1:
                      What's the error ?
                      • FollyF
                        Folly @mitu
                        I will check this evening again.
                        Not at my pi at the moment.
                          barbudreadmon @Folly
                          @Folly just curious, are there performance issues when running channelf games with other available emulators on pi0 ?
                          • FollyF
                            Folly @barbudreadmon
                            @barbudreadmon
                            Don't think so.
                            I will try them soon and let you know.
                            Channelf was just a test.
                            I helped someone who wanted to know if mame would work on a pi0.
                            He wanted to run a homebrew that only worked on mame.
                            So that was basically the reason to use mame.
                            Eventually he got it working on a pi3.
                            But I was still curious if I could get it working on a pi0.
                            Now that it works I was curious about if other "low-end" drivers could work.
                            But compiling on a pi0 takes just too much time.
                            That is why I opened this topic.
                            • FollyF
                              Folly @mitu
                              Just to see if the method works correctly I have successfully "cross-compiled" some packages.
                              For test I did a libretro-core and a standalone emulator :
                              • lr-freechaf
                              • vice
                              Going back to mame standalone now.
                              I will take some extra time to figure things out.
                              First I want to successfully compile mame on a rpi4 (for rpi4) with just one driver without changing too much parameters in the module-script.
                              Just to see if it compiles correctly.
                              Choosing just one driver will drastically reduce the time to test things.
                              If it succeeds I will move forward again other wise I will probably post the error(s).
                                You can manually compile MAME based on the scriptmodule, just use the CXXFLAGS/CFLAGS for the RPI0/1 that RetroPie uses ( -mcpu=arm1176jzf-s -mfpu=vfp -O2) when building.
                                • FollyF
                                  Folly @mitu
                                  I tried a few things to compile manually, like this :
                                  # on RPI4/8GB for RPI4, tried on both Buster and Bullseye 32 bit
                                  make SUBTARGET=msx SOURCES=msx/msx2.cpp REGENIE=1 -j2
                                  # on RPI4/8GB for RPI0/1, tried on both Buster and Bullseye 32 bit
                                  make CFLAGS='-mcpu=arm1176jzf-s -mfpu=vfp -O2' CXXFLAGS='-mcpu=arm1176jzf-s -mfpu=vfp -O2' SUBTARGET=msx SOURCES=msx/msx2.cpp REGENIE=1 -j2
                                  Somehow both fail.
                                  So I tried your fist advice again and just use :
                                  # on RPI4/8GB for RPI0/1, tried on Bullseye 32 bit
                                  Swap in module-script was set to 12288 and !arm6 flag was removed.
                                  This is the log :
                                  https://drive.google.com/drive/folders/1qTrU_eMUxpZPAXL-m9juiaJclVtNARPo
                                  This is a returning error every time :
                                  ../../../../../src/emu/validity.cpp: In function ‘void {anonymous}::validate_integer_semantics()’:
                                  ../../../../../src/emu/validity.cpp:179:31: error: static assertion failed: PTR64 flag enabled, but was compiled for 32-bit target
                                    179 |  static_assert(sizeof(void *) == 8, "PTR64 flag enabled, but was compiled for 32-bit target\n");
                                  make[2]: *** [emu.make:1410: obj/Release/src/emu/validity.o] Error 1
                                  make[2]: *** Waiting for unfinished jobs....
                                    @Folly Is your compiling system a 64bit or 32bit system ? Try adding PTR64=0 to the build options, seems MAME assumes it's building for a 64bit system (which the Pi0/1 is not).
                                    • FollyF
                                      Folly @mitu
                                      I checked my OS.
                                      It gives aarch64 as architecture but I am sure it's 32 bit.
                                      I tested it also with
                                      pi@raspberrypi:~ $ getconf LONG_BIT
                                      32
                                      uname -a gives :
                                      Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
                                      I had that same idea earlier on with PTR64=0 but in other tests it still failed.
                                      I can try again if you like.
                                        I checked my OS.
                                        The kernel may be 64bit with recent updates - see https://retropie.org.uk/forum/topic/34185. This may confuse MAME's build system thinking it's building for 64bit. You should add arm_64bit=0 to config.txt and reboot, then re-try the build.
                                        FollyF 2 Replies Last reply Reply Quote 1
                                        • FollyF
                                          Folly @mitu
                                          Good suggestion.
                                          Will reboot and will check again what the output is of uname -a.
                                          Then try again.
                                          To be sure I will also add PTR64=0 to the options in the module script.
                                          Edit :
                                          Looks promising, uname -a now gives :
                                          Linux raspberrypi 6.1.21-v7l+ #1642 SMP Mon Apr 3 17:22:30 BST 2023 armv7l GNU/Linux
                                          Compiling has started though I checked for PTR64=1 in the make files in many generated makefiles I still see :
                                          DEFINES += -DPTR64=1 -DNDEBUG -DCRLF=2 -DLSB_FIRST -DFLAC__NO_DLL -DPUGIXML_HEADER_ONLY -DLUA_COMPAT_ALL -DLUA_COMPAT_5_1 -DLUA_COMPAT_5_2
                                          I would somehow expect to see :
                                          += -DPTR64=0
                                          • FollyF
                                            Folly @mitu
                                            That were the solutions.
                                            I expect it will also work without using PTR64=0 now.
                                            Compiling seems to be about 10 hours on a RPI4/8GB which is much better than 1 month on a PI0/1.
                                            So now I have a working binary and channelf is working as expected ;-)
                                            Will try some other systems later.
                                            Thanks !
                                            • FollyF Folly referenced this topic on
