    Problems with SSH and boot
    sshboot
    5 Posts 2 Posters 472 Views
      Microwave565
      I've turned on Retropie after some updating and after the splashscreen is done showing it shows me these lines of messages. They also show up if i I'm in terminal and decide to connect via SSH. On PC it usually takes 2 or 3 times before it connects. Does anyone know how to fix these? It has also made Emulationstation really slow after the update.
      [ 3.4232411 systend-journald[121]: Assertion 'clock_gettine (nap_clock_id (cloc
      [ 3.5871271 systend-journald[137]: Assertion 'clock_gettine (nap_clock_id (cloc
      [ 3.6917431 systend-journald[152]: Assertion 'clock_gettine (nap_clock_id (cloc
      [ 3.8028251 systend-journald[156]: Assertion 'clock_gettine (nap_clock_id (cloc
      [ 3.9290911 systend-journald [157]: Assertion 'clock_gettine (nap_clock_id (cloc
      8.2314221 systend-logind [464]: Assertion 'clock_gettine (nap_clock_id (clock_id), ats) == 0' failed at ../src/basic/time-util.c:55, function nou(). Aborting. [ 8.933837] systend-logind [558]: Assertion 'clock_gettine (nap_clock_id (clock_id), ats) == 0' failed at ../src/basic/tine-util.c:55, function nou(). Aborting. [ 9.1136261 systend-logind [577]: Assertion 'clock_gettine (nap_clock_id(clock_id), ats) == e' failed at ../src/basic/time-util.c:55, function now(). Aborting. 9.2297881 systend-logind [5941: Assertion 'clock_gettine (nap_clock_id (clock_id), ats) == 0' failed at ../src/basic/time-util.c:55, function now(). Aborting. [ 9.3525581 systend-log ind [6061: Assertion 'clock_gettine (nap_clock_id (clock_id), &ts) == 0' failed at ../src/basic/time-util.c:55, function nou(). Aborting.
      Raspbian GNU/Linux 11 retropie tty1
      retropie login: pi (automatic login)
      Linux retropie 5.10.103-071 #1529 SMP Tue Mar 8 12:24:00 GMT 2822 armu?1
      The programs included with the Debian GNU/Linux system are free software: the exact distribution terms for each program are described in the individual files in /usr/share/doc/w/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
      Last login: Sun Jun 18 02:16:23 CEST 2823 from 192.168.106.71 on pts/0
      20.7302921 systend-log ind [733]: Assertion 'clock_gettine (nap_clock_id (clock_id), ats) == e' failed at ../src/basic/tine-util.c:55, function now(). Aborting. 28.776288] systend-log ind [7341: Assertion 'clock_gettine (nap_clock_id (clock_id), ats) == 0' failed at ../src/basic/tine-util.c:55, function now(). Aborting. 20.820147] systend-log ind [735]: Assertion 'clock_gettine (nap_clock_id (clock_id), ats) == 0' failed at ../src/basic/tine-util.c:55, function now(). Aborting. 20.865274] systend-log ind [7361: Assertion 'clock_gettine (nap_clock_id (clock_id), ats) == e' failed at ../src/basic/tine-util.c:55, function now(). Aborting. 20.911728] systend-logind [738]: Assertion 'clock_gettine (nap_clock_id(clock_id), ats) == ' failed at ../src/basic/time-util.c:55, function now(). Aborting.
        These messages are not from RetroPie - how did you install the system ? Is there any other service/script that you set up to at start-up ?
          Microwave565 @mitu
          @mitu I was actually trying to download Raspotify through this tutorial: https://github.com/dtcooper/raspotify
          I got stuck at .deb packages being outdated so I tried to update them and that's when I started seeing those lines.
            mitu Global Moderator @Microwave565
            @Microwave565 Then you may ask the developer(s) of raspotify about these messages, they have nothing to do with RetroPie/RaspiOS.
              Microwave565 @mitu
              @mitu Yeah that would probably be the best idea for this problem.
              Thanks for the help though, I might just do a clean install since it's a time sensitive project
