    D-Input vs X-Input on 8Bitdo controllers
    xpad8bitdox-input
    15 Posts 3 Posters 21.1k Views
      bmn001
      I've been using D-Input for years because that was just the default mode that 8Bitdo ships their controllers in. There's never been any official guidance about which mode we should use with Retropie, so I just stuck with it.
      I decided today to try out X-Input because D-Input doesn't support rumble.
      Well I switched to X-Input and rumble works great, but Emulation Station doesn't recognize the L2/R2 buttons at all.
      Hardware: Raspberry Pi 4, running the latest (as of today) Retropie.
      Joypad: 8Bitdo SN30 Pro, running the latest (as of today) firmware. Using it over Bluetooth.
      Previous posts about this made it sound like all you had to do to fix this is update the xpad driver. I un/reinstalled xpad and there was no change.
      For now I'm back to D-Input. But has anyone figured out how to make this work?
      B mituM 2 Replies Last reply Reply Quote 0
        bmn001 @bmn001
        Thanks to info in this thread I was able to edit:
        /opt/retropie/configs/all/retroarch-joypads/[name of my controller].cfg
        I then added these two lines to the end of the file:
        input_l2_axis = "+2"
        input_r2_axis = "+5"
        That makes L2 and R2 work in emulators.
        However...I'm helping out a not-so-computer-literate friend who I'm sure will manage to overwrite this setting at some point in the future by using Emulation Station's button configurator. I'd still prefer to do this in a less-hacky way if there is one.
        WeirdHW 1 Reply Last reply Reply Quote 0
          mitu Global Moderator @bmn001
          @bmn001 said in D-Input vs X-Input on 8Bitdo controllers:
          xpad only works for wired Xbox controllers, try installing xpadneo and re-pair the controller, then re-configure it in EmulationStation.
          You can disable the auto-configuration of the controller from the Configuration section in RetroPie-Setup, under the emulationstation menu.
            bmn001 @mitu
            @mitu said in D-Input vs X-Input on 8Bitdo controllers:
            Removed my Bluetooth device.
            Removed the previous udev rules after reading this
            Installed xpadneo.
            Uninstalled xpad just in case.
            Rebooted.
            Paired controller.
            Tried to configure buttons in ES and...no change. The L2/R2 buttons are not recognized.
            jstest does see the trigger presses. Just Emulation Station will not.
            Is there a way for me to confirm that xpadneo is actually being used by this controller?
              Disconnect the controller, then run - from the terminal:
              dmesg -w
              Connect the controller again and see if the xpadneo driver takes over the connection. Press Ctrl+C to stop dmesg and go back to the terminal.
                bmn001 @mitu
                @mitu Yeah that output is full of xpadneo messages referencing my gamepad. So I guess the driver is in use at least.
                Jstest does show the two triggers as axis, not buttons, if that makes a difference.
                • WeirdHW
                  WeirdH @bmn001
                  Just set Emulationstation to kiosk or kid mode after configuring. It will hide all the setup stuff.
                    Can you post the messages ? You can copy them by running the dmesg command over SSH.
                    The triggers being recognized as axis is ok and EmulationStation should be able to deal with them.
                      bmn001 @mitu
                      @mitu Yep, here's a log. I start with the controller off, then power it on and this is the output I see as soon as it connects:
                      [34441.432303] xpadneo 0005:045E:02E0.000A: buggy firmware detected, please upgrade to the latest version
                      [34441.432314] xpadneo 0005:045E:02E0.000A: pretending XB1S Windows wireless mode (changed PID from 0x02E0 to 0x028E)
                      [34441.432322] xpadneo 0005:045E:02E0.000A: working around wrong SDL2 mappings (changed version from 0x00000903 to 0x00001130)
                      [34441.432330] xpadneo 0005:045E:02E0.000A: report descriptor size: 307 bytes
                      [34441.432338] xpadneo 0005:045E:02E0.000A: fixing up report descriptor size
                      [34441.433222] xpadneo 0005:045E:02E0.000A: battery detected
                      [34441.433230] xpadneo 0005:045E:02E0.000A: enabling compliance with Linux Gamepad Specification
                      [34441.433327] input: 8Bitdo SN30 Pro as /devices/platform/soc/fe201000.serial/tty/ttyAMA0/hci0/hci0:11/0005:045E:02E0.000A/input/input23
                      [34441.446011] xpadneo 0005:045E:02E0.000A: input,hidraw2: BLUETOOTH HID v11.30 Gamepad [8Bitdo SN30 Pro] on d8:3a:dd:1c:dd:84
                      [34441.446027] xpadneo 0005:045E:02E0.000A: controller quirks: 0x00000027
                      [34442.106805] xpadneo 0005:045E:02E0.000A: 8Bitdo SN30 Pro [e4:17:d8:7a:f4:73] connected
                      I've noted the first line about "buggy firmware," but I'm already running the latest 8Bitdo firmware available (2.02) so I'm not sure what that's looking at.
                        Yeah, it looks like xpadneo takes over and applies some quirks to the controller, so it's clearly managed by xpadne.
                        Not sure why the L2/R2 buttons don't get mapped in ES, but you can start EmulationStation using the debug option and it should print what input is activated during the input configuration dialog (log is printed on console and also written in $HOME/.emulationstation/es_log.txt).
                        emulationstation --debug
                          bmn001 @mitu
                          @mitu The ES debug log seems to indicate that ES isn't seeing the triggers being pressed at all.
                          After "Mapping [Button 5] -> RightShoulder" when I was asked to press the left and right trigger buttons, I made sure to press L2 and R2 ten times each so they would be obvious in the log before I did a "hold button to skip" to move on.
                          Instead, there's nothing in the log about triggers at all, and indeed the UI gave no indication that any button or trigger was being pressed at that time.
                          Jul 12 08:30:51 lvl2:   Added known joystick '8Bitdo SN30 Pro' (instance ID: 0, device index: 0)
                          Jul 12 08:30:51 lvl3:   SystemView::getViewElements()
                          Jul 12 08:30:58 lvl2:   Configuring device 0 (8Bitdo SN30 Pro).
                          Jul 12 08:31:00 lvl2:     Mapping [Hat 0 up] -> Up
                          Jul 12 08:31:00 lvl2:     Mapping [Hat 0 down] -> Down
                          Jul 12 08:31:01 lvl2:     Mapping [Hat 0 left] -> Left
                          Jul 12 08:31:02 lvl2:     Mapping [Hat 0 right] -> Right
                          Jul 12 08:31:02 lvl2:     Mapping [Button 7] -> Start
                          Jul 12 08:31:03 lvl2:     Mapping [Button 6] -> Select
                          Jul 12 08:31:03 lvl2:     Mapping [Button 0] -> A
                          Jul 12 08:31:04 lvl2:     Mapping [Button 1] -> B
                          Jul 12 08:31:05 lvl2:     Mapping [Button 2] -> X
                          Jul 12 08:31:05 lvl2:     Mapping [Button 3] -> Y
                          Jul 12 08:31:06 lvl2:     Mapping [Button 4] -> LeftShoulder
                          Jul 12 08:31:06 lvl2:     Mapping [Button 5] -> RightShoulder
                          Jul 12 08:31:18 lvl2:     Mapping [Button 9] -> LeftThumb
                          Jul 12 08:31:19 lvl2:     Mapping [Button 10] -> RightThumb
                          Jul 12 08:31:19 lvl2:     Mapping [Axis 1-] -> LeftAnalogUp
                          Jul 12 08:31:20 lvl2:     Mapping [Axis 1+] -> LeftAnalogDown
                          Jul 12 08:31:20 lvl2:     Mapping [Axis 0-] -> LeftAnalogLeft
                          Jul 12 08:31:21 lvl2:     Mapping [Axis 0+] -> LeftAnalogRight
                          Jul 12 08:31:22 lvl2:     Mapping [Axis 4-] -> RightAnalogUp
                          Jul 12 08:31:22 lvl2:     Mapping [Axis 4+] -> RightAnalogDown
                          Jul 12 08:31:23 lvl2:     Mapping [Axis 3-] -> RightAnalogLeft
                          Jul 12 08:31:23 lvl2:     Mapping [Axis 3+] -> RightAnalogRight
                          Jul 12 08:31:24 lvl2:     Mapping [Button 6] -> HotKeyEnable
                          Jul 12 08:31:24 lvl3:   fireEvent: config-changed
                          Jul 12 08:31:24 lvl3:   fireEvent: controls-changed
                          Jul 12 08:31:24 lvl2:           /opt/retropie/supplementary/emulationstation/scripts/inputconfiguration.sh
                          Given that:
                          • xpadneo identifies and drives my controller
                          • jstest recognizes the triggers when pressed
                          • The the triggers work within retroarch when I manually edit a config file
                          • I've seen identical behavior using both xpad and xpadneo (so far)
                          ...it's looking a lot like a possible bug in Emulation Station maybe?
                          I really do appreciate you taking the time to step through all this with me. Thank you.
                            More likely with the SDL2 library used by EmulationStation underneath, which handles also the input. However, if things work with RetroArch, it's not a big deal, since L2/R2 are not really used by EmulationStation itself.
                              bmn001 @mitu
                              @mitu I have only a vague grasp of this, so please bear with me.
                              I just installed some random SDL2 controller testing tool from github. It needed libsdl2-dev installed to build. The version I used was "2.0.10+5rpi". That testing tool does correctly see the triggers.
                              So I just pulled the latest Emulation Station from github and built it on the same machine (Ras Pi4). It still will not see the triggers.
                              mituM B 2 Replies Last reply Reply Quote 0
                                What's the version of EmulationStation you have installed ?
                                  bmn001 @bmn001
                                  @mitu Whew. It's getting weird now.
                                  I just built the latest version of SDL2 from github.
                                  cmake sees SDL2 as 2.29.0 now instead of the previous 2.0.10.
                                  So then I rebuilt Emulation Station.
                                  The preinstalled Emulation Station was v2.11.2rp. The one I've built identifies as 2.12.0rp-dev.
                                  The good news:
                                  • Emulation Station now recognizes my L2/R2 triggers!
                                  The weird news:
                                  • When I launch retroarch emulators, they do not recognize my L2/R2 trigger presses.
                                  • While the bluetooth dialog still reports my controller name as "8Bitdo SN30 Pro" when I pair and connect it, this newly-built version of Emulation Station reports it as "Xbox 360 Controller".
