    Vertical text alignment problem in SNES mini theme
    themes
    1 Posts 1 Posters 412 Views
      SirPrimalform
      Update: Found a solution with a bit more persistence in googling, sorry for cluttering up the forum. Solution here for anyone following in my footsteps: https://jimmyb.ninja/post/1646839316
      Original post: This is a fresh installation and I've just downloaded and installed the SNES mini theme via the menu. The vertical alignment of the text is messed up and I'm not sure if it's user error or something else. There's a very old thread from 2017 which sounds like the same issue, but as far as I can tell the problem was resolved back then. This is what I see:
      https://photos.app.goo.gl/G7zYw7xFkiNPUh1D9
      Pi Model or other hardware: RPi3
      Power Supply used: Official PSU
      RetroPie Version Used: 4.8
      USB Devices connected: USB keyboard
      Controller used: 8bitdo Pro+ via Bluetooth
      RPi output resolution is 1080p/60Hz via HDMI.
