    Help building kodi 19
    kodi 19buildcmake
    6 Posts 2 Posters 2.0k Views
    • 1
      1101010101
      Hi
      tl;dr I wanted to build kodi 19 on retropie
      I've recently installed retropie on a pi4 2g and loved it so far. I also had success with setting up moonlight but now I would like to use kodi also. I noticed that's an old version of kodi which in general is no problem, but none of the addons I earlier used are available for this version anymore or deprecated.
      So I wanted to build kodi 19 from scratch. I have never built anything on linux. I'd say I am not a beginner but this brought me to my wits end. I saw an old post on raspberrypi forums but I couldn't get it to work.
      I got till the last point but it always failed.
      my log
      Any help is very much appreciated.
        The error comes from the fact that your USB stick is probably mounted with the noexec option and cmake tries to run/execute something from the source tree (which is copied on your USB partition).
        /bin/sh: 1: /media/usb0/kodi-build/build/ffmpeg/src/ffmpeg/configure: Permission denied
        Try running
        sudo mount -oremount,exec /media/usb0
        before running the cmake command again.
        1 1 Reply Last reply Reply Quote 1
        • 1
          1101010101 @mitu
          Hi @mitu
          I've done what you said and it ran for about an hour I'd say and then it stopped again at 51%.
          With pretty much the same error. I put it background and disowned it, so I only have the last parts it output to stdout but I can run it again if you need more information. (Then I'll pipe it to a file)
          [ 51%] Linking CXX static library settings.a
          cd /media/usb0/kodi-build/build/settings && /usr/bin/cmake -P CMakeFiles/settings.dir/cmake_clean_target.cmake
          cd /media/usb0/kodi-build/build/settings && /usr/bin/cmake -E cmake_link_script CMakeFiles/settings.dir/link.txt --verbose=2
          /usr/bin/ccache /usr/bin/ar qc settings.a CMakeFiles/settings.dir/AdvancedSettings.cpp.o CMakeFiles/settings.dir/DisplaySettings.cpp.o CMakeFiles/settings.dir/GameSettings.cpp.o CMakeFiles/settings.dir/LibExportSettings.cpp.o CMakeFiles/settings.dir/MediaSettings.cpp.o CMakeFiles/settings.dir/MediaSourceSettings.cpp.o CMakeFiles/settings.dir/SettingAddon.cpp.o CMakeFiles/settings.dir/SettingConditions.cpp.o CMakeFiles/settings.dir/SettingControl.cpp.o CMakeFiles/settings.dir/SettingCreator.cpp.o CMakeFiles/settings.dir/SettingDateTime.cpp.o CMakeFiles/settings.dir/SettingPath.cpp.o CMakeFiles/settings.dir/Settings.cpp.o CMakeFiles/settings.dir/SettingsBase.cpp.o CMakeFiles/settings.dir/SettingsValueFlatJsonSerializer.cpp.o CMakeFiles/settings.dir/SettingsValueXmlSerializer.cpp.o CMakeFiles/settings.dir/SettingUtils.cpp.o CMakeFiles/settings.dir/SkinSettings.cpp.o CMakeFiles/settings.dir/SettingsComponent.cpp.o CMakeFiles/settings.dir/DiscSettings.cpp.o
          /usr/bin/ccache /usr/bin/ranlib settings.a
          make[2]: Leaving directory '/media/usb0/kodi-build'
          [ 51%] Built target settings
          make[1]: Leaving directory '/media/usb0/kodi-build'
          make: *** [Makefile:141: all] Error 2
            mitu Global Moderator @1101010101
            @1101010101 The log doesn't show the actual error, but if you've added the exec option for the USB partition I don't see why it would fail with the same error. Perhaps the error is similar but not quite the same ? Couldn't tell without looking at the previous log lines.
            1 1 Reply Last reply Reply Quote 0
            • 1
              1101010101 @mitu
              @mitu Okay I'll run it again and provide them. :)
              • 1
                1101010101
                So yesterday I had a weird error. I thought why don't I put the nvme mount with option exec into /etc/fstab. I did that and after that it would only boot into emergency and I couldn't recover anything. I tried adding the shell to cmdline.txt but nothing helped. So I decided to completly redo my retropie setup. After redoing everything, I tried again to build kodi with all the options and it just worked fine.
                No errors nothing, it just went up to 100%. I installed it with sudo make install and it works.
                :D As stupid as this seems it probably was some bad configuration which still existed from my first tries.
                I want to thank you for your help, after I remounted my drive I thought what a godsent it would have took me atleast weeks to come up with this if ever. :D
                So this thread can be closed now.
                • windgW windg referenced this topic on
                • C c71wT6xl referenced this topic on
